This in case if u have problems in flashing
Discussion in 'Android Tablet Discussions' started by lox2013, Jan 1, 2014.
  1. lox2013
    lox2013 Member
    assert failed: getprop("ro.product.device") == "thunderc" || getprop("ro.build.product") == "thunderc"
    You do this with 7-Zip/WinRAR
    Note: DO NOT EXTRACT ROM!
    In the ROM go to:
    /META-INF/com/google/android/updater-script
    1)Open updater-script with a script editor such as notepad/notepad++ (makes things 10x easier), or gedit if you use linux
    2)Delete the first line of code (all the way up to the first semicolon you see) and delete the first semi-colon as well
    Do not go past the first semiclon when deleteing and DO NOT forget to delete the first semicolon.
    Cheers!
    Sent from my SPH-L710 using Tapatalk
having problems flashing android tablet
