Usb memory stick problems
Discussion in 'Rockchip RK2818 Tablets' started by pg0909, Jan 11, 2011.
  1. pg0909
    pg0909 Member
    TR718D
    I have TR718d China tablet and my memory stick ised to work.
    Now the tablet doesnt recognize the USB.
    Why????
  2. xaueious
    Canada
    Is the USB key still FAT/FAT32?
  3. Britt
    Britt Member
    Wisconsin
    Nook Color
    I have this problem practically every time I reboot : ) Go into settings in your menu, go into USB Mode Select and uncheck Host Mode box or check it and then uncheck. When you go back to your main screen you should see your USB device being recognized in the top left corner. Not sure if this is normal or a glitch but it solves the problem for me every time! Granted, this is if your USB port/driver isn't broken... Hope it helps!!!
how to verify an android tablet recognizes flash memory
my tab let wont read my usb drive
tf300 usb not recognized
