Using tablet for presentations?
Discussion in 'Android Tablet Discussions' started by Vlayke, May 17, 2011.
  1. Vlayke
    Vlayke Member
    Slovenia
    HTC Desire
    Hi guys,
    I've been on the lookout for a tablet for a few months now. I'm not all that wild about an iPad, so I've been considering an Android version.
    A major thing for me is ability to deliver Powerpoint presentations out to a projector. I'd be prepared to use an HDMI to VGA converter (but would be happier if it weren't needed). From what I'd seen pretty much all tablets that have any sort of video out only sport a (mini) HDMI.
    What I would like to know is, if anyone has any experience whatsoever with this kind of thing.
    Did anyone try using your tablet as a presentation device in this context?
    How does it work?
    Is there any way to then remotely control the tablet/presentation, with a remote presenter tool like the Logitech one?
    Any experience with the HDMI->VGA converters?
    Any thoughts here would be greatly appreciated.
    Thanks,
    Vlayke
  2. zcostilla
    zcostilla Member
    near St. Louis
    Acer a500
    I use my Acer tablet HDMI out for powerpoint using Docs to Go just fine.
  3. uplade3
    uplade3 Super Moderator Staff Member
    Asheville N.C.
    Flytouch II/SuperPAD Droid Charge/Razr, Galaxy S4
    I would recommend the Acer A500
  4. Vlayke
    Vlayke Member
    Slovenia
    HTC Desire
    Thanks for the suggestion.
    What about the HDMI-> VGA?
    Did you try that out at all?
    The thing is, I deliver presentations all over the world. I use projectors that are on-site. And so far the only input that I can rely on 100% to be there is VGA.
    So my if you have some experience with that, it would be easier to make a final decision :)
    Cheers,
    Vlayke
  5. nortexoid
    nortexoid Member
    Asus Transformer TF101
    I don't get why the moderator is recommending a particular tablet when any tablet with an HDMI port will do. I have an Asus Transformer with a mini (NOT micro) HDMI port and mini HDMI to VGA converters can be found on ebay for less than $10 US. My slides are done in beamer (a LaTeX package) so they're in pdf, but you could use Polaris Office (which comes with the Transformer) for MS Powerpoint or compatible documents.
    • Like Like x 2
  6. subtotal
    subtotal Member
    Auckland
    Coby 7022
    Do not buy a $10 HDMI to VGA converter off ebay, you have a better chance of Santa dropping by with a winning lottery ticket than getting a converter that actually works for this price. The only things in this price range that I could find on ebay were HDMI to VGA cables, given that HDMI is digital and VGA is analog there is no way these cables will work for 99.9% of the people who buy them.
    Realistically you're looking at $40-50 for the converter but that should do the job fine on most projectors, the only limitation I can think of is that the input resolutions vary between projectors and these converters maintain image size, so you may come across the odd projector that won't work with this setup. In that case see if you can borrow a laptop for the presentation.
    • Like Like x 2
  7. michaelwalker
    michaelwalker Member
    I'm already using a converter and the Toshiba thrive has a full size HDMI port...But the real problem is I need a clicker app that goes from my android phone to android tablet to switch slidesAnyone got ideas on that???
  8. xmorera
    xmorera Member
    Galaxy Note
    There is also another way, you can use ccview.me
    You upload your presentation, and you can share it with a link to anyone in your conf room or anywhere else
  9. userbe1155
    userbe1155 Senior Member
    plymouth
    wm8650
    Onda Vi40 Elite 9.7 Inch Android 4.0 Tablet PC With IPS Capacitive Touch Screen Allwinner A10 Onda Vi40 Elite 9.7 Inch Android 4.0 Tablet PC With IPS Capacitive Touch Screen Allwinner A10 [VI40] - $223.99 : China Tablet PC - Android Tablet PC - Consu
    hi as others have stated any tab will do these things. this tab has a standard hdmi connector so should be easier to find a convertor cable for your presentations. this seller is a supporting vendor on this forum so also you will get better aftersales service. if you contact them they may be able to supply the cable you need with the tab itself. i trust this seller better than any others i have dealt with for their honesty & no oem goods policy. theyre reliable friendly & will not tell you things are in stock when theyre obviously not. well worth a look in my view, you have nothing to lose by checking them out.
acer a500 how to use presenter for powerpoint presentation
dynamic presetnations on tablets
how use presenter for tab galaxy
presentations with galaxy tab four
tablet teaching presentations
using a tablet for av presentaion
using a tablet for powerpoint but need presenter or clicker
using a tablet for presentations
using android tablet for presentation
what is the best way to do a listing presentation using tablet
