What is the Model of My Tablet and What ROMs Work On It?
Discussion in 'WonderMedia Based' started by gracco, Jun 12, 2011.
  1. gracco
    gracco Member
    Hi I have a tablet pc Chinese 7 ", 256 ram, light blue (no vibration at boot time), audio jack black, model WM 8650, kernal 2.6.32.9, Android 2.2, generic-english Froyo Ver. 1.3.1-20110513.075040.
    what it is the model of my tablet and what roms works on it?
    Regards
  2. jamiesk
    jamiesk Member
    Ipswich
    MID WM8650 7inch
  3. gracco
    gracco Member
    thnks ...my tablet is this:
    Product detailed map
    [​IMG][​IMG]
    [​IMG]
    [​IMG]
    7" GOOGLE Android REAL 2.2 WiFi Camera MID Tablet PC 3G
    This one can is Real Android 2.2 , Can use Flash 10.1 and App market
    CPU
    Type
    VIA VT8650 ARM926 600-800 MHz
    OPERATING SYSTEM
    Operating System
    Real Google Android 2.2
    LCD
    Size
    7" TFT LCD
    Resolution
    800x480
    Touch Screen
    Full Size,High Sensitive Touch Operation
    SYSTEM MEMORY
    Spec
    Real 256MB Memory
    STORAGE DEVICE
    Type
    Nand Flash
    Capacity
    2GB
    Camera
    Pixel
    0.3Mega
    AUDIO
    Output
    Built-in Stereo speakers
    Input Device
    Built-in Microphone
    COMMUNICATION
    LAN
    External Fast 10/100 Mbps Ethernet Adapter
    WLAN
    Built-in 802.11b/g WLAN Card
    SUPPLEMENTAL DRIVE
    Card Reader
    TF/MMC Card slot X 1
    I/O PORT
    USB
    USB2.0 X 2
    Audio Port
    Headphone X 1
    AC ADAPTOR
    AC Power Adaptor
    100V Input, 9V DC Output, 2A
    BATTERY
    Battery Pack
    2400 mAH Batteries
    PHYSICAL SPEC
    Dimension
    19.9*12.8*0.8-1.4cm
    Weight
    0.37KG
    OTHER
    G Sensor
    Yes
    Languages
    Arabic, Bulgarian, Catalan, Croatian, Czech, Danish, Dutch, English, Spanish, Finnish, French, German, Greek, Hebrew, Hindi, Hungarian, Indonesian, Italian, Japanese, Korean, Latvian , Lithuanian, Norwegian, Poland, Portuguese, Romanian, Russian, Serbian, Slovakian, Slovenian, Swedish, Tagalog, Thai, Turkish, Ukrainian, Vietnamese, Chinese (Traditional), Chinese (Simplified)
    Software
    Fring,QQ,MSN,Youtube,Google Map,Document to go,Multimedia Player,Email,Es File Explore,Application Store
    Accessory
    AC Adapter,User Manual,External RJ45/USB Pot
  4. jamiesk
    jamiesk Member
    Ipswich
    MID WM8650 7inch
    It seems like the one I got off ebay too. Same box, same picture of it. Mine has a black USB/Ethernet jack. If you are not happy with whats on there, then give it a try. I got mine for £49, so not much to loose. I got the ROM in my sig, and run the batch file for option 2. Good luck.
  5. meetballhead
    meetballhead Member
    lndon
    tablet
    I am having a headache with this. I have a green LED and black jack. Have tried nearly all the options and nothing gets past the updating screen :confused:
  6. peleri
    peleri Member
    Norway
    7" UMPC GOOGLE Android 2.2 WiFi Camera MID Tablet PC 3G
    Hello!
    This is my first post to this forum. I have the same tablet, that gracco has. I have installed the WM8650 1.3.0 HYBRiD HoneyCombMOD , and pressed option 2. I get it all "up and running", except the Wifi. Any sulution to this?
  7. responderman
    responderman Member
    Lincoln, England
    Epad
    If you loaded the light version it seems to have WIFI problems, try the full version it seems to work OK.
  8. mkulkarni
    mkulkarni Member
    Hi, Thanks for the detailed info.
    I have lost my Power Adaptor and purchased a new on
    AC Power Adaptor100V Input, 9V DC Output, 2A
    But, the pin diameter does not match up. Any idea about the pin size to fit in.
    Thanks for help.
    Regards,
    Mangesh
mid tablet 9v arm 926
mid tablet via arm 926 usb
