The battery on my 7022 is somewhat "bouncy". When I first got it the battery would go from 50% with heavy use, then when I stop using it the battery would creep back up to 55-60%. Over time the battery is stabilized for the most part and is much more accurate about how it drains. For the first few uses it would even charge to 100% and then within a few minutes drop down to 70%... but now it charges to a full charge and properly drains down from there.
Probably just due to cheap lithium batteries. Make sure to give your tablet a few full charges.... drain it all the way down till it turns off, then full charge a couple of times.
