wifi connection
Discussion in 'Coby Tablets' started by norco1, Nov 1, 2011.
  1. norco1
    norco1 Member
    florida
    coby kyros 7024
    I own a Coby Kyros 7024 tablet. I recently lost my wifi connection. My router is operative and signal strength is excellent, however settings to the internet displays a "disabled" description . I do have a neighbor with wifi that intermittently interferes with my signal. Any suggestions to retrieve the internet? The router (tp-link) rep says it's a tablet issue. Please advise.
  2. lfom
    lfom Senior Member Developer
    Brasil
    WiFi is disabled or the connection (your base's SSID) is disabled? If it's the connection, log press it, choose "forget", then try to connect again. If you have changed anything on your router it may not connect again. Try removing the password first, if it works then try WPA/WPA2 PSK with an 8 digit password.
  3. Pickupman66
    Pickupman66 Member
    Tennessee
    Samsung Captivate (Rooted) Coby Kyros 1024
    Also make sure your router broadcasts on a different channel.
    Sent from my rooted, baked, Gingerbread rocking Kyros MID1024
  4. Raphael_Carlos
    Raphael_Carlos Member
    Rio de Janeiro
    Tablet Coby Kyros 7016
    Eu tenho um MID 7016 e toda vez que entro na internet pelo WIFI(único jeito que eu acho que existe), me mostra a mensagem página não pode ser exibida.
    Como faço para isso não aparecer. Existe alguma configuração!!!!!!!!!!!!!
    Obrigado desde já!!!!!!!!!!!!!!!!!
  5. lfom
    Brasil
    O idioma oficial do fórum é inglês (que eu saiba, não existe um seção em português). Se você precisa de ajuda em português, sugiro que procure outro fórum ou use um tradutor online.
    The official language of this forum is English (I am not aware of a Portuguese section). If you need help in Portuguese I suggest that you look for another forum or use an online translator.
android tablet lost wifi connection
coby 9 inch kyros tablet wifi connection
coby tablet wifi connection
coby tablet wireless connection
coby wireless connect
kobe kyros wifi says it is disabled
lost my connection on my tablet
lost my wifi connection on my android tablet
