Zeki 10.1" (TBQG1084NB) - Need Firmware
Discussion in 'Zeki Tablets' started by Hotsuma, Sep 25, 2019.
  1. Hotsuma
    Hotsuma Senior Member
    Pompey Town
    Zeki 10.1" Android Tablet
    Zeki 10.1" Quad Core Tablet with 8GB, 1GB RAM, Android 4.2.X Jelly Bean
    This tablet is stuck in a permanent boot-loop. The recovery mode is weird because when I boot into it, it won't let me do anything (it's frozen). After a while, it'll power down. I bought this tablet off of eBay years ago and began having problems a few months ago. I want to fix this issue myself so I won't have to pay out of pocket to have it fixed. I have several HD photos of the chips on the board and also a shot of the board model #.
    This is a quad-core tablet, and so I'm having a hard time figuring out which chips are the processors. Is anyone able to tell me and possibly show me where to get the firmware from?
    -----Update-----
    Ok, So, the processor is the one with:
    MEDIATEK
    ARM
    MT8163V
    1637-BBCTH
    CCMKYRHT
    Written on it. When I search for firmware using MT8163 or MT8163_Android_scatter, I got a few hits. I downloaded those firmwares and flashed them to my Zeki 10.1" Quad-Core tablet using SP Flash Tool (which works great) but unfortunately, those firmwares aren't compatible with my tablet. I learned how to use SP Flash Tool when I tried the first firmware. They have great guides on how to use it. SP Flash Tool is only for firmwares that use the Android_scatter file.
    So far all of the firmwares I have tested aren't compatible with my tablet. I know this because it will either freeze the tablet when I power it on, show a blank screen, or boot-loop with audio only. I need the firmware for this tablet. The processor's model number is MT8163V and the board # - EM_T8511A_KEY_V3.0.
    Shot of whole tablet:
    [​IMG]
    Board Model #
    [​IMG]
    Shot of Chips
    [​IMG]
    Last shot of chips:
    [​IMG]
  2. Traveller
    Traveller Super Moderator Staff Member
    Coby Kyros MID9742, Lenovo Tab 4 (8"), numerous phones
    Check Zeki's website as they may have the firmware there. Otherwise be prepared to call Zeki and shell out money for the privilege of having your device repaired.
    I will say though that the recovery freezing is not a good sign at all. That usually means a hardware issue.
  3. Hotsuma
    Pompey Town
    I bought it from eBay years ago. I noticed on the back of the tablet it has the model number but the space for the serial number was blank. I think this is one of those Chinese tablets but it worked good for a while. I checked the website and I don't see any firmwares. I did email them a few days ago asking for the firmware but they have yet to reply back. I guess I'll give them a call and see how much they're going to charge me. I have no intention of paying anyone though.
  4. Traveller
    Honestly, it's likely not worth getting repaired unless Zeki is only charging a song and a dime due to the age of the tablet. You may be better off with something newer.
  5. Hotsuma
    Pompey Town
    I contacted Zeki and they said that they didn't have the firmware for this tablet and so they can't fix it. I am considering tossing it but another part of me is saying keep it because I might end up finding the firmware one day. But there's one thing that's been bugging me about this motherboard. Where is the actual processor? When looking at other motherboards, there's one big chip that says something like A23. But this board doesn't have a big chip.
    Here's a better shot of the chip in the lower left-hand side of this picture:
    [​IMG]
  6. Traveller
    The chip in the lower left IS the processor. Zeki used a phone CPU in the tablet: Mediatek is quite common in budget smartphones from China.
  7. Hotsuma
    Pompey Town
    Ok. I'm done searching for the firmware. I'm tossing it out in the morning. Thanks anyways.
  8. q88
    q88 Junior Member
    I hope you did not toss it out. I have the same problem with what looks like the same tablet. There must be a solution to this...
  9. Hotsuma
    Pompey Town
    Sorry. I tossed it already. And bought a new tablet. No one has the firmware for that tablet. Best of luck.
zeki firmware
