I recently purchased a 10.2" ZTPAD running Android 4. It took some getting used to as I had only used desktop and laptop pcs before and nothing touchscreen. But now I love it and use it a lot.
However one of the main reasons I purchased it was because of the proported long battery life. I have found this not to be the case. Although the ad said I should get 5-6 hours from the battery the most I am getting is 2.5 and that is with WIFI and everything else I can think of switched off and the screen brightness turned down to the point I can just see it.
With WIFI enabled I get an hour!
I contacted the supplier and they said to charge the battery for 5-6 hours for the first few charges.
But although I tried this from the start I found that the charge only goes for 2 hours. After that the pad says that the battery if fully charged and stops charging. So I can't charge it for 5-6 hours.
Do I have a faulty battery?
Has anyone else any ideas of anything I can switch off to conserve battery life?
