Background data problem
penseiro
9
I have noticed something odd: when I check de background data option, later me screen starts shaking and it gets blocked, and I can´t do nothing unless I reseted the tablet and unckeck this option? Someone knows whats going on? It is some corrupted apk?
It is an Acer iconia A500, not rooted.
Shaking?
How can a screen shake? Are you talking about the haptic feedback?
Do you have wifi turned on, and wifi disconnect option set to Never?
The interface starts going sideways, out of control. Incredible, no one has the same problem. Second time I have this problem and no one understands.
No one understands because a) no one else has ever seen this, or b) your description is so poor we can't understand what is going on.
Interface going sideways. Shaking. Those two things don't sound anything like each other.
Get your cell phone out and take some pictures and post them here or on youtube.
Nobody else has reported any problem with background data causing any screen problems what so ever.
Its just an hipothesys, the background data thing, I dont know if its the cause of the problem. I will filme and put here.
"sideways" to me sounds like the screen rotation feature.
If so, then maybe you are holding the tablet in a way that makes it rspidly switch between portrsit and landscape. Try locking the screen with the screen lock switch.
Otherwise, yes, please show us the issue.
Sent from my SAMSUNG-SGH-I777 using Android Tablet Forum
