Help Please. Can I intall Wifi USB on my tablet?
pasxalis2000
My android tablet has not very good wifi (internal)
then, I buy a external usb WiFi like
TL-WN722NC
but the problem is that i do not know how I install the USB WiFi.
Please help me
TL-WN722NC
Please help me
The short answer is that you can't.
If your WiFi is that bad you may want to look at your WiFi router as the problem unless you have installed an app that is interfering with it. Restart your router and possibly look at changing the channel. Install WiFi Analyzer to see if you get some help there re: channel selection. That could make a big difference.
If the problem is that you are too far away to get a good signal a WiFi booster.repeater might also help but they don't need to be connected to your tablet.
