Where did my battery/wifi/settings icons go?
ronyvee
Last night my battery and wi-fi icons, settings button, all around info station located on the botom right of my screen disappeared. I must have done something inadvertantly to cause this. How do I get them back?
i would bet you had a widget for those and it got deleted. Press and hold on the desktop until you get a popup, select add widget and you should be able to find one preloaded that says power control or similar.
No widget, but I did find a battery app-icon that seems to give me the same info. Thank you so much for your quick help!
