7022 Screen Rotation not working
Discussion in 'Coby Generation 2' started by penecow290, Aug 2, 2011.
  1. penecow290
    penecow290 Member
    I recently had my 7022 outputing hdmi to my tv I unhooked the HDMI cord and turned off the tablet. Since then my screen is not rotating when I turn the table (it stays in landscape mode.) The check box under display settings for Auto Rotate is checked and I cannot uncheck it. Any suggestions or has anyone else had this issue?
  2. delsolboyz
    delsolboyz Member
    Coby MID7022-4G
    that's kind of strange. have you try hard reset the tablet using the reset button in the back of the unit?
  3. nba1341
    nba1341 Senior Member
    California
    Coby Kyros MID7022
    And if reset doesn't work maybe try a auto rotate widget and toggle that?
  4. penecow290
    penecow290 Member
    Installed a toggle widget but toggling does nothing, have tried the hard reset. I am going to hook it back up to hdmi when I get home to see what happens
  5. penecow290
    penecow290 Member
    Actually I just figured it out, under output settings it had stayed output to HDMI changed to LCD now I can toggle and it is rotating. :)
  6. dsharpe
    dsharpe Member
    I am looking for a feature like your problem. I have an application that is portrait and needs to be displayed through HDMI onto a big screen. The problem with my application is that it rotates to Landscape as soon as HDMI is plugged in. Is this a way to prevent the rotating to Landscape?
android hdmi auto landscape problem
my cnm tablet wont rotate
my colby tablet won auto rotate
