7048 Problem with Internal SD Card
acidburn23
135
Guys we can help each other to fix this problem share your idea's to fix this because i have this problem with my tablet in 5 months lol, how about you how long do have problem in your Internal SD Card Godbless...
samirnge
11
I have the same problem, i tried everithing , root and gasp, updates, nothing works .There is a way of format de internal sd memory from pc, linux or windows?PS: The USB mass storage work fine in your tablet
Jun 5, 2013
8
hey your internal SD Card is good? do you have a Solution for my Internal SD Card? cause my internal SD Card is not responding i can only install application from Google PlayStore only
Hey acidburn23, my internal SD card has an issue of erasing itself after I move apps to it and reboot the tablet, but the apps/data show up if I unmount my external sd card and reboot. I have no idea why it happens or how to fix it... but my apps/data are back on the internal sd after a reboot.
Edit 1: I am not tech savvy but I follow instructions well...if i find a solution somewhere, I will post a link (if permitted) or send you a private message but would prefer the link be public for other Mid7048 users.
Edit 4: I think it may be a Launcher issue but I have no evidence or information yet.
I ordered my tablet from a lottery website (for 14,200 scratch-off ticket points) in September '12 and got it in October '12. All of their electronics are Coby, and I wanted a tablet. I started moving apps to the internal sd card in March '13, so I didn't know it was faulty for 5 months.
acidburn23
135
the private message is permitted then if it is 100% working we can share it to others because this is the problem of 7048 the internal SD Card is not mounted
eaking007
30
I got problem too. REMEMBER ME ACIDBURN?
Im semi noob . but it think try
to install CWM (or use a non permanent CWM)
I got this idea because i have 2 phones (both android both have CWM)
I see a mount selection when on recovery...
But no Dont DO THIS...
its just an idea...
