Big problem with NOOK Tablet
Discussion in 'Nook Tablet' started by jnm0332, Jul 28, 2012.
  1. jnm0332
    jnm0332 Member
    NOOK Tablet
    Hi,
    I followed the directions in this procedure: http://forum.xda-developers.com/show....php?t=1402190. It seemed to work, that is the NOOK found the software on the SD card and installed it. When it booted up, the error message "Sorry! The process android.process.media has stopped unexpectedly. Please try again. Force close." So I press Force close but the error comes back immediately. I have tried redownloading and installing the acclaim_update.zip file several times. And tried using a different SD card. I have also tried rebooting the NOOK many times but it's just stuck in this error loop. Any ideas?
    I am running a NOOK Tablet 16GB. It was on OS v1.4.3 prior to installing the acclaim_update.zip file.
    Thanks for any help.
  2. Androidfonefan
    Androidfonefan Senior Member
    St. Louis Mo
    iPad2 32, Toshiba Thrive 32. Lenovo IdeaPad A1, ICOO D90W
    Just wondering if the nook is running a android based OS which is Linux at it's core. How did you install a zip file on the device when zip files are compressed windows based files or programs and can not be run on Linux natively.
    Sent from my A1_07 using Tapatalk 2
  3. J515OP
    Northern CA
    This is pretty much the way all ROMs and rootings are done. There is no problem installing zip files from recovery like ClockWork Mod or TWRP or factory recovery mode.
  4. J515OP
    Northern CA
    You need to clear your caches. Since you are trying to restore to an earlier version of Nook Tablet OS, a factory reset will work. Power down then power on pressing tand holding both the n button and the power button. When prompted to reset follow the directions. Otherwise you need to go into Settings>Apps>All app find google services frame work then stop it clear it and reboot.
    • Like Like x 4
  5. jnm0332
    jnm0332 Member
    NOOK Tablet
    I installed the zip file from my Micro SD card. The factory reset worked like a charm - thank you very much! I'm back at v1.4.3 and I'm staying there. :)
    Thanks for all of the help!
  6. Androidfonefan
    St. Louis Mo
    Ok, was just wondering, it doesn't seem to make sense to me but if that is how it is done and works then keep on keepen on.
  7. J515OP
    Northern CA
    Of course :) That is how we all learn and share.
    Glad you are up and running again. Always nice when things get back to working.
  8. Fairhope
    Fairhope Member
    Fairhope, Alabama
    Asus TF300T
    Hi, I posted on another thread, but then saw this one. I was told that my Nook tablet could not be rooted. When they were first sold they could, then BN got wise and send an update to prevent it from happening. Have I misunderstood? Is there a way now that it can be rooted?
  9. J515OP
    Northern CA
    Just asking once is sufficient. See answer in the other thread http://www.androidtablets.net/forum/nook-tablet/35591-how-root-nook-tablet.html#post230730.
  10. mlnease
    mlnease Member
    This was extremely useful as well as quite simple. I searched for hours via Google and several forums before happening on this one. Hope you don't mind mentioning here that my problem is SOLVED for others searching for a solution to "The process android.process.media has stopped unexpectedly. Please try again." Thanks again!
    • Like Like x 2
force close nook tablet
nook force close
nook message application has stopped unexpectedly
nook tablet problems
nook tablet twitter app force close
nook tablet twitter force close
nook twitter error
twitter device stopped unexpectedly error on nooktablet
twitter error on nook
twitter force closenook
