Broke my NC USB Cable
Discussion in 'Nook' started by avi, Aug 27, 2011.
  1. avi
    avi Moderator Staff Member
    India
    Nook Color
    Well most of you already know that NC's USB cable's tip is delicate & today I broke it :(
    I Googled & found that those Non B&N cables take a lot of time compared to original ones. Is it true ? Or Cheap cables also work ?
    Some Black Berry phone cables are also similar [USB Hot sync] can I use them ?
    Problem is I am from India & importing original cable costs a bomb :-/
    they still giving free cable replacement or stopped ? I know they never ship it to India :p
  2. idontknow
    idontknow Alternate ATF App Tester
    miami,fl
    galaxy note,galaxy 8.9 ,nook color
    Give me your address.Avi,I'll send you mine...I don't have any use anymore since somebody stole my nook. I'm looking into getting a used one and they all come with the charger.
    Gloria
    Sent from my LG-MS690 using Android Tablet Forum
    • Like Like x 4
  3. avi
    India
    Nook Color
    Wow ! That's great...Thanks a lot :D
    ygpm :)
  4. ShutterPeep
    ShutterPeep Member
    Nook Color Gen. 1
    Avi, how did yours break exactly? I am being very careful with mine since I'm also not from the US. If I break mine, then it'd be a lot of trouble to get a replacement too.
  5. Spider
    Chicago, IL
    @SP Mine apparently broke trying to support the weight of it's own cord. I had the nook on a table with the connector sticking out over the edge and the cord hanging down to the floor where the charger was plugged in. After a while I noticed the orange light looked funny and saw the connector had broken. It's very fragile. Maybe coating it with clear nail polish or something to strengthen it would help.
  6. ShutterPeep
    ShutterPeep Member
    Nook Color Gen. 1
    Thank Spider. On it's own weight? Jeez, it is fragile. I've been careful enough not to bang the ends or anything but this just scares me.
    I've read about the nail polish but haven't given it much thought. I've got some epoxy that would probably hold it better sans the look...
  7. Spider
    Chicago, IL
    I think you're right, epoxy would probably be stronger, Just don't cover up the cute little Orange/Green light.:rolleyes:
  8. ShutterPeep
    ShutterPeep Member
    Nook Color Gen. 1
    Yeah, I better not cover that cute little thingy. :eek:
  9. idontknow
    miami,fl
    d
    Shutter Peep, don't worry about your charger, if anything happens to it , I'll send you one as well......think of me as the guardian angel of all chargers outside the USA!
  10. ShutterPeep
    ShutterPeep Member
    Nook Color Gen. 1
    Jeez Gloria, such a lovely person you are! :eek:
  11. idontknow
    miami,fl
    Avi, my cable is on its way to India...let's hope it makes it there! And if it does, it will be yours.
    Gloria
    • Like Like x 2
  12. avi
    India
    Nook Color
    Thanks a lot gloria :D
  13. idontknow
    miami,fl
    I got my nook....are you keeping truck of your cable, Avi?
    • Like Like x 2
  14. TNRonin
    TNRonin Member
    Middle TN
    D1, Nook Color (soon)
    I'm new to the forum, I frequent another forum with people like you Gloria. I'm glad I'm here. Sorry to hear about your Nook color getting taken. I just got mine and I'm pending a root. LOL
  15. idontknow
    miami,fl
    Wellcome to the forum TN ronin.....I hope you mean something good for " people like me"! What does it mean that you are pending a root?
nook cable india
