Charging Hubs
Discussion in 'Samsung Galaxy Tab 10.1 Development' started by arfi3, Jun 5, 2013.
  1. arfi3
    arfi3 Member
    Illinois
    Samsung Galaxy Tab 7 and 2 10.1
    I am trying to find out if there is a way I ca connect a USB hub that can be used while also charging my tablet at the same time??
  2. astherion
    astherion Member
    Moldova, Bender
    Samsung Galaxy Tab 10.1 GT-7500 (16GB, 3G+WiFi, ClockworkMod 10.1 Nightly - Android 4.2.2)
    You can use script to charge it from USB.!!!
    1. Tab must be Rooted!!!
    2. Make new .txt file (USB Charging Script.txt) and fill inside following:
    #!/system/bin/sh
    su
    echo 1 > /sys/class/power_supply/battery/force_usb_charging
    3. Put file inside SD-card.
    4. Download SManager (not from Play Market, from different place!) and install it.
    5. Open Script Manager - > select your script -> check "Run as root", "Run on Boot", "Run"
    6. When ask root permissions -> Enable
    7. Enjoy!!! Now you tab always must charge from USB (also from car charger, 100% true, I use it!-)))
  3. zender92
    zender92 Member
    Could that way damage the battery or somet something else?
android charging hub
battery script for galaxy tab 10
can i use a usb hub on an android tablet
charge script android
charging hub for asus tablet
charging tablet and using usb hubs
tablet charing while usb hub
usb hub that also charges tablet
