USB Hub 2.0 Recommendation for Coby Kyros MID7036-4
Discussion in 'Coby Tablet Accessories' started by osckid, Apr 27, 2013.
  1. osckid
    osckid Member
    2341 Azalea Court Pembroke Pines, FL 33026
    coby kyros
    Would like too find a compatible USB 2.0 hub? If possible would prefer one that uses a power supply so USB devices would take power from Hub instead of tablet.
    tHANKS!:)
  2. osckid
    osckid Member
    coby kyros
    Usually when you get no answer in a tech forum the answer is probably obvious. :eek:
    I'm waiting for a gender changer adapter to go from mini USB 2.0 recepticle (female) to USB 2.0 recepticle (female). From there I can start testing power usb 2.0 hub. I'm guessing if there is an issue here I may need a driver and/or edit a usb xml file.
    Kind of primitive but I didn't pay allot for this muffler! :rolleyes:
  3. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    My guess any hub would work, I use cheap powdered hubs myself.
    Sent from my SPH-D710 using Android Phone
  4. osckid
    osckid Member
    coby kyros
    Finally, the gender changer came in and plugged in the powered hub, keyboard, mouse optical and it works at first blush.
    Still need to test further and report back any funnies but sure is nice being able to use a fullsize keyboard and mouse on a 7" tablet!:cool:
  5. dhtreanor
    dhtreanor Member
    Dallas, TX
    Samsung Galaxy Player 5.0; Coby MID 7036-4
    Thanks for your 30 Apr 2013 post about using a fullsize keyboard and mouse on a 7" tablet - wondering if it's still working good?
    Also - I'm a newbie to this world, did you need to "root" the MID7036-4 to gain this capability?
    What gender changer did you use - and what powered hub? Trying to gain that capability myself, very new to the program and am looking for all the insights I can get.
    Thank you.
coby kyros mid7036 usb charging
driver for keyboard for coby mid7036
drivers tablets coby kyros 7036
usb drivers for coby kyros mid7036
