compatible charger
Discussion in 'Coby Tablet Accessories' started by exalt228, Nov 24, 2011.
  1. exalt228
    exalt228 Member
    Philippines
    Asus eee Pad Transformer and Coby Kyros MID7015
    Hi Guys,
    I'm looking for a compatible charger for my COBY Kyros MID7015. Does anyone know where I can buy one here in the Philippines?
    Thanks in advance for any help..
  2. RobKort
    RobKort Senior Member
    Pennsylvania, US
    Acer Iconia A500, Atrix 4G(2), SonyEricsson Xperia Play, Galaxy Nexus, AT&T Avail
    Are you able to access Amazon online store there? That is were I get most of the accessories for my electronics.
    Sent from Rob's TapadaAtrix :)
  3. lfom
    lfom Senior Member Developer
    Brasil
    You just need a charger (power supply) with the same voltage (V) and at least the same number of amperes (A) or power (W) that uses the same plug and polarity (+ and - connections).
    For instance (these numbers are examples): if the original charger is 5V and 2A (or 5V x 2A = 10W), you need one with exactly 5V and at least 2A or 10W (if it's 3A or 15W it's OK, it can be more but not less). Of course, check the plug that goes in the tablet to make sure it's the same type and the + and - connectors are the same (usually one is the inside connector and the other one is outside the plug).
  4. exalt228
    exalt228 Member
    Philippines
    Thanks for the help guys!
    I've gone "MacGyver" on the factory charger and spliced the chewed up wires together and got my tablet to charge today. I'll go charger hunting this weekend to try and locate a more permanent solution to my charger woes.
android phone charger compatible with dell vue tablet
coby tablet charger philippines price
compatible chargers for coby tablet
how to charge a coby kyros without charger
how to charge coby kyros without charger
price of charger of coby tablet in philippines
what chargers are compatible with my tablet
what kind of charger can u use with coby kyros tablet
what type of charger for coby kyros mid9742-8
