DroPad help?
Discussion in 'Android Tablet Q&A' started by kcw93, Jan 24, 2012.
  1. kcw93
    kcw93 Member
    DroPad
    Hello everyone, this is my first tablet. I purchased and received this DroPad A8T? tablet from Dropad - Android 2.3 Tablet with 7 Inch Capacitive Multi-Touch Screen (WiFi, 1.2GHz CPU, Camera, 1080P, External 3G) - US$ 149.99 and while it runs very smoothly, the access to the Marketplace is extremely limited! Down in the LOW hundreds. There is a strange app that was pre-installed called "Updatter" and when opened, prompts to download something called "712b-2.3.18" now, I downloaded this 90mb .img file and when completed, it says to reboot the device. I turned my device off/on but nothing has ever changed. Many .apk files do not even install.. things like Facebook for Android and even YouTube (which is pre-installed) doesn't work. Under the "About device" it states:
    Updatter
    Status - Battery, etc.
    Legal information
    Model number - MID_Serials
    Android version - 2.3
    Baseband version - Unknown
    Kernel version - 2.6.35.7 MID Serials #187 Fri Oct 28 03:34:33 EDT 2011
    Build number - MID Serials 2.3 GINGERBREAD 20111024.162719
    Any help on the "Updatter"/.img file issue and anything else would be very much appreciated! It is a good device but the lack of access to the full Android market renders the tablet almost useless. I have downloaded some .apk files, Facebook and YouTube, but they do not install so that method will not work here. Is this device rooted, does it need to be? It apparently needs to be updated but I dont know what to do with the upgrade.img file or how it works. Please help me here!
    EDIT: I wanted to add for more info that on the Market through google on a desktop, under every app it shows my devices and for nearly all apps, it displays "Verizon Unknown MID_Serials" for this tablet. Do I need to somehow change this? Please, any all help will be appreciated.
    UPDATE: ok guys, so I managed to update the tab in some sense. "About Device" now states:
    About Device
    Urbetter Updater
    Legal Information
    Model Number - MID_Serials
    Android Version 2.3
    Baseband Version - Unknown
    Kernal Version - 2.6.35.7 MID Serials #30 Fri Sep 23 04:58:32 EDT 2011
    Build number - MID Serials 2.3 GINGERBREAD 20110921.113041
    I'm not sure what any of this means, but nothing but the "Updatter" changing to "Urbetter Updater" is different. Still very few apps compatible. Also, the "Urbetter Updater" downloads "712b_gingerbread_2.3.18_20110924.img.rar.partial" I don't know what any of this means so again, any and all help will be very much appreciated! Thanks.
    UPDATE: okay, so after rooting the device I was able to edit the density. After rebooting and clearing Market data, many more apps are now available! Still wondering if I need to change model number or anything like that so please help if you can! Thanks.
  2. sunsunny123
    sunsunny123 Member
    Hi I have same problem I have a8 dropad 2.3.18 gingerbread 20110924 but cant get full market apps it keeps telling me it is not compatible with apps i also tried rom update but makes no difference any help would be welcome not sure how to change density
  3. kromanstl
    kromanstl Member
    ST.louis MO
    Dropad A8T
    First you have to root the get root explorer after that open root explorer then find build.prop press and hold the build.prop then open text editor after that scroll down to lcd change it from 200 to 160 and remove the # sign from in front of that line and then save and restart the tab and thats it
  4. yuifann
    yuifann Member
    android 3.0
    I am not able to save the changes with Txt editor for Build.Prop.
    Can you advise for an alternative? :p
    Thanks & Best Regards,
    Yui
  5. dabesiv
    dabesiv Member
    United States
    Dropad A8t
    Can you either explain how to root or point me in the direction of where to learn, i can't find anything that's worked.
  6. kcw93
    kcw93 Member
    DroPad
    Sure, from New Dropad A8T available - SlateDroid.com
    1: run ginger break (ALREADY INSTALLED WITH dropad a8t unBrick.rar ) ID NOT DOWNLOAD IT FROM (
    http://forum.xda-dev...d.php?t=1044765)
    2: run adb shell (on your PC)
    3: cd /system/bin
    4: ./su
    4.1: super user app should ask you do allow this (ON DROPAD SREEN)
    5: rm /system/busybox/bin/su
    6: REBOOT AND 100% ROOT
  7. tmf2004
    tmf2004 Member
    FL
    Android Dropad A8
    I just got my Dropad A8 tablet today from DealExtreme. This is my first tablet and bought it new for $138.00... I just recently found that Updatter thing 712b-2.3 that the OP found. Is this important or necessary to download? I'm not really looking to Root mainly to play games and run the Torque App for my car. Although the market place is limited the tablet is pretty nice for the money...
  8. timtak
    timtak Member
    Japan
    NEC Medias Tab N08D (previously SmartQ X7 but the GPS did not work)
    I am thinking of a dropad since they seem to fulfill my criterior
    Android
    7 inch
    GPS (want to log big rides and not get lost)
    TF (hopefully for expandability)
    OTG (full size keyboard)
    There is conflicting information on whether these tablets GPS work or not. I would only need rough logging and google maps.
    I am also not sure if the Dropad's that have TF card have a SIM card (or whether only one or the other).
    Ideally I would like it to replace my phone -- using it as a 7inch smart phone. I am not sure if my Japanese carrier is at all compatible (i am with au).
    Update Since my Japanese provider's SIMS don't work in anything but their own hardware, I gave up on a SIM. I bought a Smartq X7 for its GPS speed of operation.
android gingerbread japan tablet hard reset
cant access dropad android market
dropad
dropad a8x hard reset
ebay ta8t dropad o compatible
how do you hard reset a dropad gingerbread
how do you update kernel dropad
how to change email for dropad android market
how to unbrick dropad a8t
urbetter updater
