generic flytouch wifi problem 7" 256 via 8505
Discussion in 'Gome Flytouch Problems' started by indiandevil, Dec 13, 2010.
  1. indiandevil
    indiandevil Member
    Connecticut, USA
    Generic Flytouch
    Hi,
    I have the MID 7" with via 8505 chip, 2gb, 256.
    I have tried several ROM's they work, but there is a problem with all of them.
    the wifi connections seems to be very unstable. if there a way to boost up wifi connection, looks more like a hardware problem. what can be done ? any inputs.
    thanks
  2. hoben02
    hoben02 Senior Member
    usa
    epad zenithink zt-180
    could be the issue with internet security configuration try changing the router to "wpa2"
  3. indiandevil
    indiandevil Member
    Connecticut, USA
    Generic Flytouch
    i did that.. one other person had in this forum had the problem of not connecting, changing to wpa2 corrected the problem. I did that. the tablet connects, works for sometime, but then disconnects on its own. then reconnects when it wants to and disconnects the same way.
    i read somewhere that there is a freaking antenna inside which might be a problem, but i have no clue how to open this thing up.
    if i win the 5th day of christmas tablet on this forum.. this one goes to chopping block.. internals will be hacked.. ;-)
  4. Matsuka
    Matsuka Senior Member
    Madrid, Spain
    I have the same problem. Wifi conection is very unestable with all the rooms i have installed. It is a hardware or a software problem?
    Is there one solution for this?
  5. ipal
    ipal Member
    NULL
    yeah its hardware. same here. cheap quality . thats why ipad is $600 and ours $80
  6. Hagi
    Hagi Member
    vienna, austria
    MID Generic Tab with Android 1.6
    hi guys,
    I also have the mid generic 7" tablet. I am very happy with it but I have problem:
    At home I have a wap secured wlan network which works well. As I also want to go online when I am not at home, I downloaded on my Nokia x6, the light version of the app "JoikuSpot", which allows to share my 3G Connection via a OPEN wlan-network. The app works great, I tested it with my pc and my notebook. But the preinstalled wifi-manager says the network is not in Range. So I downloaded an alternative Wifi-Manager which "sees" the Network, but when I click on it and click conect it does nothing. I also tried with a "normal" open Network and the same problem occured.
    Can anybody tell me, what the problem is?
why will my wifi not work on the flytouch x6
