Help Flytouch clone generic !!!
Discussion in 'Gome Flytouch Problems' started by antracide, Dec 17, 2010.
  1. antracide
    antracide Member
    Hi guys
    They are in possession of a Tablet I Flytouch clone from the picture with 1.6 Fw 256 ram etc etc I tried to install various scripts found that h and everything seems to be successful but all the Vole can not calibrate the touch screen calibration always tells me failure even if I do it with the mouse and I can not use the touch because I know going out of calibration part of the screen, but every attempt I get the same thing CALIBRATION FAILED!
    Heeeeeeeeeeeeelp!
  2. antracide
    antracide Member
    Nada ? :-(
  3. antracide
    antracide Member
    touchscrren working but not calibrated and no way to calibrate it I always know calibration failed! I also tried to edit the file touchcal but not knowing what are the 7 blocks of numbers in case I tempt you! Nobody could take his EPAD touchcal file that is located in / data / directory wmtpref and let me try? Maybe so 'I can solve! I can not understand what the problem ....
    Thanks.
flytouch touch calibration failed
