Help! I think i've bricked my S7
Discussion in 'Huawei Ideos S7 Technical' started by lanka53, Jun 19, 2011.
  1. lanka53
    lanka53 Member
    Sydney
    Huawei Ideos S7
    I was trying install a kernel to use with SetCPU: http://www.androidtablets.net/forum/huawei-tablets/4604-overclocking-kernal-s7.html
    However, the S7 is now stuck and it turns on and shows "Huawei S7" and then goes to a black screen. After a minute, it says
    process system is not responding" and then i can choose between "force close" and "wait" and neither help.
    What can i do?
  2. bobrien4975
    bobrien4975 Member
    Boulder,CO
    Huawei S7
    Click Wait it will load
    -brendon
  3. pvella
    pvella Senior Member
    Melbourne
    Huawei S7
    Try to reboot recovery. Hold menu+send+power and turn on.
  4. bobrien4975
    bobrien4975 Member
    Boulder,CO
    Huawei S7
    Then istall from there
    -brendon
  5. lanka53
    lanka53 Member
    Sydney
    Huawei Ideos S7
    It shows a screen with a progress bar then it disappears and goes back to the hanging screen.
    Anything else?
  6. bobrien4975
    bobrien4975 Member
    Boulder,CO
    Huawei S7
    You need to hold them for a long time till a menu in green text like old school terminalcpops up
    -brendon
  7. pvella
    Melbourne
    Huawei S7
    Try a new download of the rom.
  8. lanka53
    lanka53 Member
    Sydney
    Huawei Ideos S7
    I tried this. It starts off at the Ideos logo and then goes to a green screen and the loops between the two.
    Haha i held buttons for a couple of minutes :(
    How would i go about doing this. I can't power on the Tablet which means I can't connect it via usb, right?
  9. pvella
    Melbourne
    Huawei S7
    Get a stock rom. Put the two files in dload on the sdcard. Reboot machine to load the rom.
  10. lanka53
    lanka53 Member
    Sydney
    Huawei Ideos S7
    Would i need to buy a Mini SD adaptor to put the files onto the Mini SD?
  11. pvella
    Melbourne
    Huawei S7
    You will have to now. Since you need a working device to mount sdcard any other way.
  12. lanka53
    lanka53 Member
    Sydney
    Huawei Ideos S7
    Nevermind, I managed to work it out. I just used the update tool and it reinstalled the original 2.1 firmware.
    Thanks for all of your help. It's great to see that the Android community is so friendly :)
how to unbrick huawei s7-105
