help no touch screen after firmware upgrade
Discussion in 'Gome Flytouch Problems' started by agatok, Dec 4, 2010.
  1. agatok
    agatok Member
    NULL
    :( upgraded from build 2.0 to 2.0_88 now no touch screen, home button not working and volume always changing with beep.
    i have a 256M blue light flytouch.
    please advise on what to do.
    appreciate your help.
  2. clicku
    clicku Member
    NULL
    Does anybody also experience "Process System Stop Responding" Then a dialog box saying "force close or Wait". After rebooting the unit will just load and not continue to desktop?
  3. agatok
    agatok Member
    NULL
    i have found a solution at the slatedroid site. but my touchscreen works then after a while it stops.
    any suggestions?
  4. indiandevil
    indiandevil Member
    Connecticut, USA
    Generic Flytouch
    try different firmwares.. thats what i did..
android customer firmware no touchscreen
android touch firmware
android touch screen firmware
firmware touchscreen android
how to flash touch screen firmware
touch display firmware for android
Touch not working after software upgrade in Wm8850 mid
toucscreen firmware update android
wm8850 touch not working after install firm
