help
Discussion in 'Zenithink ZT180 10 Generation 1' started by Andrew, Jan 7, 2011.
  1. Andrew
    Andrew Member
    St.Julian's Malta
    ZT-180
    hello
    I just bought a ZT-180 e pad and i am a bit confused. Should i be able to play games where i can tilt pad like an ipad? when i try to play games nothing is moving.
    and another thing is that when i am trying type something there is always t-9 and i would like to remove it.
    Thanks if someone can help i would really appreciate
  2. pbrauer
    pbrauer Administrator Staff Member
    Edina, MN USA
    Why don't you take a look at the Infotomic section of this site, it is where the other ZT-180 threads are, you will most likely find all sorts of answers there.
  3. Andrew
    Andrew Member
    St.Julian's Malta
    ZT-180
    thanks
    will do
    Andrew
  4. xaueious
    Canada
    The ZT180 has an orientation sensor, not a g-sensor.
