Home made charger for Huawei S7 + other devices
Discussion in 'Huawei Ideos S7 Accessories' started by thek135, Apr 21, 2011.
  1. thek135
    thek135 Senior Member
    New South Wales, Australia
    Telstra T-Touch Tab AKA Huawei Ideos S7-104 - Running ivy's 1.00b custom Singapore ROM
    Upon looking at various chargers and adapters laying around my house, I stumbled upon a PSP charger. I looked at the volts and amps and they were exactly the same as the stock charger (5V 2A). I obviously have a PSP but I somehow found another PSP charger at my school and I was told I could have it seeming that no one really owned it.
    One problem, the plug on the end is too big. Does anyone know a retailer in Australia that sells the right type of plug?
    Another more ingenious solution could be to attach a USB socket to the PSP charger and connect a cable with the right adapter and use that. This might be a good option if you have multiple devices: USB Multi Charger Cable For iPod and iPhone NDSi PSP NOKIA etc - Free Shipping- - TopBuy.com.au
    I think the 8210 connector is the right one, can anyone confirm that?
  2. thek135
    I have done some vigorous searching and have come to the conclusion that the Nokia 8210 has a 3.5mm plug, which is too large.
    Sometimes I wish companies would just include plug sizes instead of making us search for hours for them. I have, however, come up with a solution: I can still get the multi cable mentioned above, but I could lop off an adapter that I won't use (e.g: the Nintendo DS/DS Lite ones) and then solder on the right plug from here: CONN DC PWR PLUG 0.9X3.2X9.0MM - PP-017. The inside diameter of 0.9 mm is right isn't it?
  3. thek135
    I just discovered a big hiccup in my plan, shipping outside of the U.S. for one of those plugs can be as much as $34 to Australia, possibly more elsewhere. Does anyone know another place to buy these plugs?
  4. thek135
    Ok, I've created the PSP Charger to USB adjustment and tested it with my Motorola V3x's USB charging cord and it works. All I need now is a USB cord with the appropriate sized pin.
  5. thek135
    I have found a very cheap Magellan Roadmate car charger which I have become aware fits the S7: Car Charger For Magellan Roadmate 800, 860, 2000 2200T | eBay. I don't need a car charger so I'm going to lop off the cord and the plug and attach it to one of the ends of the multi charger cable mentioned in the first post. From there it's a matter of covering the bare wires with heatshrink tubing.
  6. pa49
    pa49 Senior Member
    UK
    Huawei S7, Nokia X3-02, Nokia E71
    Good to have the idea mentioned again!
  7. thek135
    You mean the Magellan charger?
  8. pa49
    pa49 Senior Member
    UK
    Well actually everything has been mentioned before.
charge huwaei s7 slik via usb
charger huawei s7 use for lg tablet
charger ideos s7 jack size
hauwei s7 slim charger vol
home made charger for android
how to get hauwei s7 slim to charge through usb
huawei tablet charger
i want to buy a huawei ideos s7 tablet charger
size of pin for huawei s7 charger
what charger works on huawei
