How to Side Load Apps If Market Won't Work
Discussion in 'Android Tablet Usage, Tips & Tricks' started by probbiethe1, Aug 2, 2010.
  1. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
  2. rich_l
    rich_l Member
    STL
    Moto Xoom
    I wanted Gazelle - a medical app from Quest Diagnostis but according to Plotz Store and Quest it doesn't run on the Xoom. I got a copy, sideloaded it and it works just fine on my Xoom:
  3. probbiethe1
    Gilbert, Arizona
    Great job, way to be
  4. exgi
    exgi Member
    Portland Oregon
    Irulu 10.1
    Try "ES File Explorer" it's free and very useful! You can get it on Google play (formally known as the android market) Good luck!
  5. urstrinath
    urstrinath Member
    India
    HCL
    Nice trick thanks for sharing the information...
  6. probbiethe1
    Gilbert, Arizona
    You are very welcome.
  7. Pat Cook AKA Bach Patu
    Pat Cook AKA Bach Patu Junior Member
    My problem is Google Play doesn't even detect the prescence of my SKYTEX SP1020 on the GP website EVEN THOUGH it's on, has THE SAME Google ID (In fact, it has ALL of my Google Accounts on it just like my Android phone does) & is on THE SAME network as my phone is (GP detects my phone with no problem however)
    I'm thinking this is because GP is only "Trained" (For lack of a better word) to only look for devices registered or otherwise "Branded" by the telcos (My tablet isn't "Branded" by any telco because I don't wanna be left with a useless electronic board should I decide to leave my carrier for one of their competitors :) )
    Sometimes, I can find the apps I want on my tablet via the GP app itself, however I sometimes get greeted by a message saying the app is incompatible with my tablet (The Fos Sports GO app is an example of this)
    Sometimes it's just plain BS (Like I think is the case with Fox Sports GO because BOTH the NBC Sports Live Extra & WatchESPN apps run without ANY issues whatsoever on my tablet) & sometimes it's not. But I have no way of knowing for sure or finding out for myself though :(
    Given this, a way to sidelad apps (Or download the APK to my PC & transfer them to my tablet to install) would help as a backup to the traditional direct download from GP & other markets via the tablet itself)
    Would a sideloader help in my case ??
    Cheers :)
    Pat
  8. Jeffrey
    Jeffrey Super Moderator
    Thailand
    If you have a tablet/phone that does not allow you to access the Play Store and you want Google approved apps on your device, simply go to https://hola.org/ and install their app or browser addon. Now you can log into google US Play Store and many sites that are blocked by your country if you are outside the US.
  9. Pat Cook AKA Bach Patu
    ZERO BYTE file dude :(
  10. sumeet1
    sumeet1 Junior Member
    Can you help with the name of few App stores other than Google play and Amazon?
  11. Spider
    Chicago, IL
android market wont load
applanet filecrop
apps of wonderappstore
how to sideload android apps tablet
market app wont work
side load apps acer
slideload
why want my android market work on 3d stereoscopic
wonderappstore
wonderappstore apk
