Need help for my android tablet pc
Discussion in 'Android Tablet Discussions' started by sombel, Aug 12, 2011.
  1. sombel
    sombel Member
    New E10 MID android version OS 2.2 / Kernel 2.6.32 / Build number V1.5.0
    hi all
    I have an android tablet pc with these specifications:
    Specification E10
    CPU:VIA8650 800MHz up to 1GHz
    OS:Android 2.2 (Support Flash 10.1) 256MB DDR2
    Kernel: 2.6.32
    Buid Number: V1.5.0
    Storage Device:4GB
    My problem is i have put a 32GB sd card and my tablet started to reboot constantly then i push the reset button and when the device start it's appear a non-stop green android logo flying and turning around itself above a half green circle.
    I removed the sd card / done many reset but the device still display a non-stop green android logo flying and turning around itself above a half green circle.
    Please help me!
  2. sombel
    sombel Member
    Is there no android specialist in this forum !
  3. wicced247
    wicced247 Member
    brooklyn
    Coby Kryosmid7024
    What is the brand of tablet? Who makes it?
    Sent from my Coby Kryos MID7024 not-rooted with 16gb microSD
  4. sombel
    sombel Member
    it's only wrote MID on the package but i baught it with this name New E10 android 7'' tablet pc
  5. wicced247
    wicced247 Member
    brooklyn
    Coby Kryosmid7024
    That could be anything. But it sounds like ur tablet dont support a 32gb card and trying to run it screwed up the tablet files. Try a factory reset.
  6. sombel
    sombel Member
    i withdraw the 32GB card and i have push the reset button but when the device start after booting it display me the same problem.
    Can you explain me step by step how to put a firmware on it .
    thanks.
  7. wicced247
    wicced247 Member
    brooklyn
    Coby Kryosmid7024
    Go into settings/location and security/clear memory
  8. sombel
    sombel Member
    i can't acceed in any setting because when i turn on the device and right after the booting it's just display the green android logo turning around itself.
  9. wicced247
    wicced247 Member
    brooklyn
    Coby Kryosmid7024
    U will have to do a factory reset and i dont know what exactly is ur device. U will have to figure out how to do that
  10. sombel
    sombel Member
    When i presented the problem to my supplier i ask me my New E10 tablet pc need to upgrade the android and she give me a software now i am asking how to update step by step the android.
    it 's an android OS 2.2 / Kernel: 2.6.32 / Build Number: V1.5.0
beltab factory reset
how to flash beltab
