Need help on Link2sd -Coby Kyros M1024-4g
Discussion in 'Coby Generation 2' started by mharckk, Dec 24, 2011.
  1. mharckk
    mharckk Senior Member
    philippines
    COBY KYROS MID1024-4G
    after having troubles in getting my coby to be rooted i just installed the EVO CFW by Ifom (thanks). now its rooted. :) now the problem is i cant make the link2sd to work. tried the instructions on the developer itself on xda forum but its not working.
    when i try to run it says:
    mount script error
    mount script cannot be created
    mount: mounting /dev/block/vold/179:2 on /data/sdext2 failed: device or resource busy
    jeez another problem. :) can anyone can help me?
    anyway Merry Christmas to all.
  2. mharckk
    philippines
    after searching finally got the answer by installing the lower version of link2sd 1.7.
    1. partition the external sd card mine is 16gig (10gig FAT32 and 5gig ext2) both primary with mini tool partition wizard home edition (im ok with this no problem at all)
    2. insert the external sd card into tablet. (this was easy)
    3. run the link2sd and when it asked what type of partition i just need to choose the "ext2"
    4.reboot then open again the link2sd now working.
    5. install latest version of link2sd 1.9
    im happy now cause my coby is rooted with cool CFW and with running link2sd.
device or resource busy link2sd
error mount link2sd in coby tablet
link2sd device or resource busy
link2sd device or resource buzy
link2sd error device or resource busy
link2sd log device or resource busy
link2sd resource busy error
mount device or resource busy android link2sd
mount script cannot be created device or resource busy
