Onda VI40 V3 vanilla 1.1 firmware
Discussion in 'Onda Tablet Forum' started by maddog1979, May 13, 2012.
  1. maddog1979
    maddog1979 Member
    Warrington U.K
    Onda Vi40
    Hi everyone, first post.
    I've taken the Onda stock 1.1 ICS firmware and stripped it down for everyone to do
    with it as they please. (my first attempt)
    Changes
    •Language set to English
    •Locale set to
    Europe/London
    •Chinese apps removed
    •CWM installed and novotools 7 APM
    (thanks to genolokar) to allow you to boot into recovery (although the hard
    buttons are a bit off until i can figure out how to change them. power is
    select, menu is down, home is up and back is back)
    • Simple Market fix
    •Red border
    fix
    •Busybox installed (if prompted please install to /system/bin NOT
    /system/xbin/ as this is believed to casue issues.
    •Gmail
    •Kingsoft
    Office
    •Maps
    •Nav
    •Play music
    •Root
    explorer
    •Superuser
    •Youtube
    Asus weather widget
    I've tested this on my VI40 with no
    issues but i'd like to stress this is my first attempt at this so use at your
    own risk. If you do choose to try this out after flashing please leave the
    device for around 10-15 mins whilst it installs all the apps.
    This is
    ONLY for V3 models.
    Rapidshare
    Just use Livesuit to flash as normal.
    • Like Like x 2
  2. James2205
    James2205 Member
    United Kingdom
    Onda Vi40 Elite
    Hey mate, thanks for this, am gonna give it a go - once the rapidshare file finally D/L's!!! Do you have it posted anywhere else?
    Cheers
    James
como rotear onda vi 40 v3
