Reboot Loop on my A101 - HELP!
Discussion in 'Archos Tablets' started by ozzmeister00, Feb 13, 2011.
  1. ozzmeister00
    ozzmeister00 Member
    Sarasota, FL
    Hello All,
    I ran through the steps to install the full 2.2 upgrade, and installed the Google Marketplace good and proper. I started downloading some applications, and a bunch of them refused to download. I thought I needed to reset my wireless connection, to no avail. Then I did what I always down, and I rebooted the tablet.
    Now it's stuck in a reboot loop. It boots up, hangs for a moment, gets to the home screen, and a few moments later it kicks back the error "Sorry! Process system is not responding" and I have the option to force close, or wait. If I force close, it reboots. If I wait, it reboots.
    Anyone have any ideas/suggestions? I'm totally open to doing a factory reset but I'm not sure how.
    -Ozz
  2. ozzmeister00
    ozzmeister00 Member
    Sarasota, FL
    Okay, got it to do a full reformat, but it gets caught up at "USB Connection: Press OK to disconnect". I press "OK" with it plugged into my computer and it gives me "Update failed: (1)".
    After that I reboot it and it goes to Recovery. I run a format again and the same thing happens.
  3. ozzmeister00
    ozzmeister00 Member
    Sarasota, FL
    Nevermind. I need to update the firmware this time around after the wipe. If this happens again I'll revive the thread. I really would like to know what's going on with the reboots.
  4. maaarek
    maaarek Member
    please, how you moved on when your archos got stucked? I can't do anything...
  5. ozzmeister00
    ozzmeister00 Member
    Sarasota, FL
    The reason it kept hitting a reboot loop was because whichever format option I chose completely wiped the OS off the device, and no installer package for the OS existed on the thing, so I had to download the OS from Archos and get the package on it.
  6. maaarek
    maaarek Member
    please, how you did it? can you write me quick steps?
  7. ozzmeister00
    ozzmeister00 Member
    Sarasota, FL
  8. maaarek
    maaarek Member
    hi,
    i made firmware update (or downgrade :) ) by placing firmware Froyo Firmware 2.3.20 file on archos.. Then Archos detected firmware file and made auto update (downgrade)..
    Now it seems to work correctly and without any problems.. 5 days without any Reboot loop..
acer a101 bootloop
acer a101 bootlop
acer iconia a101 boot loop
acer iconia a101 bootloop
acer iconia a101 stuck on boot screen
acer iconia tab in a start-up loop
archos 101 g9 loop boot
archos 101 g9 stuck on sutem recover
archos a101 recover password
archos boot loop
archos g9 boot loop
archos loop
archos shutdown loop
bootloop inconia a101
