Discussion in 'Huawei Ideos S7 Slim Technical' started by asturel, Aug 27, 2012.
  1. asturel
    asturel Senior Member
    Hungary
    Huawei IDEOS S7 Slim
    It mostly for Huawei S7 Slim (201u), if you have different device, may some feature will not work.
    download @
    http://goo.im/devs/asturel
    CM9 code is frozen (by cyanogenmod), so no more cm9 builds (except if its device related)
    DONT FORGET TO WIPE ! NO WIPE NO SHINE !
    USE AT OWN RISK, I'm not responsible if you burn your house/face/etc down
    THIS IS AN UNOFFICIAL ROM, SO DON'T BOTHER CM DEVS WITH THIS!
    P.S.: CPU runs at 998Mhz
    any advice/support/etc is welcome
    YOU HAVE TO INSTALL ONE OF THE FOLLOWING RECOVERY TO ABLE TO INSTALL THE ROM:
    recoveries:
    2012-10-20: new cwm recovery (supports sideload (adb sideload zip, extended commands e.g. openrecovery (e.g. able to install new rom via goomanager app)
    (note: twrp is a touch recovery)
    most of builds doesnt contain device specific update, just cm's updates.
    • Like Like x 83
  2. lzzmn
    lzzmn Member
    Thanks for your great effort.
    I have think S7 becomes a dead mobile.
    It's you, regenerated it!
    Hope we can get a perfect CM9.
    And, could you please tell me how to use it?
    • Like Like x 4
  3. ere95588
    ere95588 Senior Member
    great job
    but my phone is s7 ,not slim
    can you make s7 kernel?
  4. asturel
    Hungary
    is it rly different than s7 slim kernel? or it just uses different touch/etc driver?
    I left all drivers in the kernel, but a kernel config ( /proc/config.gz ) would rly help
    • Like Like x 2
  5. Jota
    Jota Member
    BH, Brazil
    Ideos S7_105
    Thanks for your efforts!
    I think it will help with the development of this rom, if you manage to build a working rom for the S7 classic, because there are much many more S7 classic devices in use out there than are Slim's.
    As far as I tested, your recovery.img gives a blank screen on the S7 classic.
    Also, the 2.2.2 boot.img for the slim (from the original UPDATA.APP) does not work on the S7 classic.
    So, I guess there must be some diferences on the kernels.
    For my S7 I use the boot image from the last 2.2.2 Russian rom.
    # Automatically generated make config: don't edit
    # Linux kernel version: 2.6.32.9
    # Wed Jul 6 19:05:36 2011
    CONFIG_ARM=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_GENERIC_GPIO=y
    CONFIG_GENERIC_TIME=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_GENERIC_HARDIRQS=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_HAVE_LATENCYTOP_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_RWSEM_GENERIC_SPINLOCK=y
    CONFIG_ARCH_HAS_CPUFREQ=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y
    CONFIG_OPROFILE_ARMV7=y
    CONFIG_VECTORS_BASE=0xffff0000
    CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
    CONFIG_CONSTRUCTORS=y
    # General setup
    CONFIG_EXPERIMENTAL=y
    CONFIG_BROKEN_ON_SMP=y
    CONFIG_LOCK_KERNEL=y
    CONFIG_INIT_ENV_ARG_LIMIT=32
    CONFIG_LOCALVERSION="$(KERNEL_LOCAL_VERSION)-ideos"
    # CONFIG_LOCALVERSION_AUTO is not set
    # CONFIG_SWAP is not set
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_BSD_PROCESS_ACCT is not set
    # CONFIG_TASKSTATS is not set
    # CONFIG_AUDIT is not set
    # RCU Subsystem
    CONFIG_TREE_RCU=y
    # CONFIG_TREE_PREEMPT_RCU is not set
    # CONFIG_RCU_TRACE is not set
    CONFIG_RCU_FANOUT=32
    # CONFIG_RCU_FANOUT_EXACT is not set
    # CONFIG_TREE_RCU_TRACE is not set
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    CONFIG_LOG_BUF_SHIFT=17
    # CONFIG_GROUP_SCHED is not set
    # CONFIG_CGROUPS is not set
    # CONFIG_SYSFS_DEPRECATED_V2 is not set
    # CONFIG_RELAY is not set
    # CONFIG_NAMESPACES is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
    # CONFIG_RD_BZIP2 is not set
    # CONFIG_RD_LZMA is not set
    CONFIG_CC_OPTIMIZE_FOR_SIZE=y
    CONFIG_SYSCTL=y
    CONFIG_ANON_INODES=y
    CONFIG_PANIC_TIMEOUT=0
    CONFIG_EMBEDDED=y
    CONFIG_UID16=y
    CONFIG_SYSCTL_SYSCALL=y
    CONFIG_KALLSYMS=y
    # CONFIG_KALLSYMS_ALL is not set
    # CONFIG_KALLSYMS_EXTRA_PASS is not set
    CONFIG_HOTPLUG=y
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_ASHMEM=y
    CONFIG_AIO=y
    # Kernel Performance Events And Counters
    CONFIG_VM_EVENT_COUNTERS=y
    CONFIG_COMPAT_BRK=y
    CONFIG_SLAB=y
    # CONFIG_SLUB is not set
    # CONFIG_SLOB is not set
    CONFIG_PROFILING=y
    CONFIG_TRACEPOINTS=y
    CONFIG_OPROFILE=m
    CONFIG_HAVE_OPROFILE=y
    # CONFIG_KPROBES is not set
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    # GCOV-based kernel profiling
    # CONFIG_GCOV_KERNEL is not set
    # CONFIG_SLOW_WORK is not set
    CONFIG_HAVE_GENERIC_DMA_COHERENT=y
    CONFIG_SLABINFO=y
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
    # CONFIG_MODULE_FORCE_LOAD is not set
    CONFIG_MODULE_UNLOAD=y
    CONFIG_MODULE_FORCE_UNLOAD=y
    # CONFIG_MODVERSIONS is not set
    # CONFIG_MODULE_SRCVERSION_ALL is not set
    CONFIG_BLOCK=y
    CONFIG_LBDAF=y
    # CONFIG_BLK_DEV_BSG is not set
    # CONFIG_BLK_DEV_INTEGRITY is not set
    # IO Schedulers
    CONFIG_IOSCHED_NOOP=y
    # CONFIG_IOSCHED_AS is not set
    CONFIG_IOSCHED_DEADLINE=y
    # CONFIG_IOSCHED_CFQ is not set
    # CONFIG_DEFAULT_AS is not set
    CONFIG_DEFAULT_DEADLINE=y
    # CONFIG_DEFAULT_CFQ is not set
    # CONFIG_DEFAULT_NOOP is not set
    CONFIG_DEFAULT_IOSCHED="deadline"
    CONFIG_FREEZER=y
    # System Type
    CONFIG_MMU=y
    # CONFIG_ARCH_AAEC2000 is not set
    # CONFIG_ARCH_INTEGRATOR is not set
    # CONFIG_ARCH_REALVIEW is not set
    # CONFIG_ARCH_VERSATILE is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_ARCH_CLPS711X is not set
    # CONFIG_ARCH_GEMINI is not set
    # CONFIG_ARCH_EBSA110 is not set
    # CONFIG_ARCH_EP93XX is not set
    # CONFIG_ARCH_FOOTBRIDGE is not set
    # CONFIG_ARCH_MXC is not set
    # CONFIG_ARCH_STMP3XXX is not set
    # CONFIG_ARCH_NETX is not set
    # CONFIG_ARCH_H720X is not set
    # CONFIG_ARCH_NOMADIK is not set
    # CONFIG_ARCH_IOP13XX is not set
    # CONFIG_ARCH_IOP32X is not set
    # CONFIG_ARCH_IOP33X is not set
    # CONFIG_ARCH_IXP23XX is not set
    # CONFIG_ARCH_IXP2000 is not set
    # CONFIG_ARCH_IXP4XX is not set
    # CONFIG_ARCH_L7200 is not set
    # CONFIG_ARCH_KIRKWOOD is not set
    # CONFIG_ARCH_LOKI is not set
    # CONFIG_ARCH_MV78XX0 is not set
    # CONFIG_ARCH_ORION5X is not set
    # CONFIG_ARCH_MMP is not set
    # CONFIG_ARCH_KS8695 is not set
    # CONFIG_ARCH_NS9XXX is not set
    # CONFIG_ARCH_W90X900 is not set
    # CONFIG_ARCH_PNX4008 is not set
    # CONFIG_ARCH_PXA is not set
    CONFIG_ARCH_MSM=y
    # CONFIG_ARCH_RPC is not set
    # CONFIG_ARCH_SA1100 is not set
    # CONFIG_ARCH_S3C2410 is not set
    # CONFIG_ARCH_S3C64XX is not set
    # CONFIG_ARCH_S5PC1XX is not set
    # CONFIG_ARCH_SHARK is not set
    # CONFIG_ARCH_LH7A40X is not set
    # CONFIG_ARCH_U300 is not set
    # CONFIG_ARCH_DAVINCI is not set
    # CONFIG_ARCH_OMAP is not set
    # CONFIG_ARCH_BCMRING is not set
    # CONFIG_ARCH_MSM7X01A is not set
    # CONFIG_ARCH_MSM7X25 is not set
    # CONFIG_ARCH_MSM7X27 is not set
    # CONFIG_ARCH_MSM7X30 is not set
    CONFIG_ARCH_QSD8X50=y
    # CONFIG_ARCH_MSM8X60 is not set
    CONFIG_MSM_SOC_REV_NONE=y
    # CONFIG_MSM_SOC_REV_A is not set
    CONFIG_ARCH_MSM_SCORPION=y
    CONFIG_MSM_VIC=y
    CONFIG_MSM_REMOTE_SPINLOCK_LDREX=y
    # MSM Board Selection
    # CONFIG_HUAWEI_INCIDENT_LED is not set
    CONFIG_MACH_QSD8X50_SURF=y
    # CONFIG_MACH_QSD8X50_SURF_ORG is not set
    # CONFIG_MACH_QSD8X50_SURF_RU920 is not set
    # CONFIG_MACH_QSD8X50_SURF_H21 is not set
    CONFIG_MACH_QSD8X50_SURF_S7=y
    CONFIG_MACH_QSD8X50_SURF_S70=y
    CONFIG_MACH_QSD8X50_SURF_S7_S7=y
    # CONFIG_MACH_QSD8X50_SURF_S7_S7103 is not set
    # CONFIG_MACH_QSD8X50_SURF_S7_S7201 is not set
    # CONFIG_MACH_QSD8X50_SURF_S7_S7_T0 is not set
    # CONFIG_MACH_QSD8X50_SURF_S7_S7_T1 is not set
    # CONFIG_MACH_QSD8X50_SURF_S7_S7_A is not set
    CONFIG_MACH_QSD8X50_SURF_S7_S7_B=y
    CONFIG_MACH_QSD8X50_SURF_S7_S7_HWVER_T0=1
    CONFIG_MACH_QSD8X50_SURF_S7_S7_HWVER_T1=2
    CONFIG_MACH_QSD8X50_SURF_S7_S7_HWVER_A=3
    CONFIG_MACH_QSD8X50_SURF_S7_S7_HWVER_B=4
    CONFIG_MACH_QSD8X50_SURF_S7_S7_HWVER=4
    # CONFIG_MACH_QSD8X50_FFA is not set
    # CONFIG_MACH_QSD8X50_COMET is not set
    CONFIG_MSM_STACKED_MEMORY=y
    CONFIG_PHYS_OFFSET=0x20000000
    CONFIG_PMEM_GPU0=y
    CONFIG_MSM_AMSS_VERSION=6225
    # CONFIG_MSM_AMSS_VERSION_6210 is not set
    # CONFIG_MSM_AMSS_VERSION_6220 is not set
    CONFIG_MSM_AMSS_VERSION_6225=y
    CONFIG_MSM_DEBUG_UART_NONE=y
    # CONFIG_MSM_DEBUG_UART1 is not set
    # CONFIG_MSM_DEBUG_UART2 is not set
    # CONFIG_MSM_DEBUG_UART3 is not set
    # CONFIG_MSM7X00A_USE_GP_TIMER is not set
    CONFIG_MSM7X00A_USE_DG_TIMER=y
    CONFIG_MSM7X00A_SLEEP_MODE_POWER_COLLAPSE_SUSPEND=y
    # CONFIG_MSM7X00A_SLEEP_MODE_POWER_COLLAPSE is not set
    # CONFIG_MSM7X00A_SLEEP_MODE_APPS_SLEEP is not set
    # CONFIG_MSM7X00A_SLEEP_MODE_RAMP_DOWN_AND_WAIT_FOR_INTERRUPT is not set
    # CONFIG_MSM7X00A_SLEEP_WAIT_FOR_INTERRUPT is not set
    CONFIG_MSM7X00A_SLEEP_MODE=0
    # CONFIG_MSM7X00A_IDLE_SLEEP_MODE_POWER_COLLAPSE_SUSPEND is not set
    # CONFIG_MSM7X00A_IDLE_SLEEP_MODE_POWER_COLLAPSE is not set
    # CONFIG_MSM7X00A_IDLE_SLEEP_MODE_APPS_SLEEP is not set
    # CONFIG_MSM7X00A_IDLE_SLEEP_MODE_RAMP_DOWN_AND_WAIT_FOR_INTERRUPT is not set
    CONFIG_MSM7X00A_IDLE_SLEEP_WAIT_FOR_INTERRUPT=y
    CONFIG_MSM7X00A_IDLE_SLEEP_MODE=4
    CONFIG_MSM7X00A_IDLE_SLEEP_MIN_TIME=20000000
    CONFIG_MSM7X00A_IDLE_SPIN_TIME=80000
    CONFIG_MSM_IDLE_STATS=y
    CONFIG_MSM_IDLE_STATS_FIRST_BUCKET=62500
    CONFIG_MSM_IDLE_STATS_BUCKET_SHIFT=2
    CONFIG_MSM_IDLE_STATS_BUCKET_COUNT=10
    CONFIG_MSM_SUSPEND_STATS_FIRST_BUCKET=1000000000
    # CONFIG_MSM_JTAG_V7 is not set
    # CONFIG_HTC_HEADSET is not set
    # CONFIG_HTC_PWRSINK is not set
    CONFIG_QSD_SVS=y
    CONFIG_QSD_PMIC_DEFAULT_DCDC1=1250
    CONFIG_MSM_FIQ_SUPPORT=y
    # CONFIG_MSM_SERIAL_DEBUGGER is not set
    CONFIG_MSM_PROC_COMM=y
    CONFIG_MSM_SMD=y
    # CONFIG_MSM_SMD_PKG3 is not set
    CONFIG_MSM_SMD_PKG4=y
    CONFIG_MSM_SMD_DEBUG=y
    CONFIG_MSM_N_WAY_SMD=y
    CONFIG_MSM_N_WAY_SMSM=y
    CONFIG_MSM_RESET_MODEM=m
    CONFIG_MSM_SMD_LOGGING=y
    CONFIG_MSM_SMD_NMEA=y
    CONFIG_MSM_SMD_TTY=y
    CONFIG_MSM_SMD_QMI=y
    CONFIG_MSM_SMD_PKT=y
    CONFIG_MSM_ONCRPCROUTER=y
    CONFIG_MSM_ONCRPCROUTER_DEBUG=y
    # CONFIG_MSM_RPC_LOOPBACK_XPRT is not set
    CONFIG_MSM_RPCSERVER_TIME_REMOTE=y
    CONFIG_MSM_RPCSERVER_WATCHDOG=y
    CONFIG_MSM_RPC_WATCHDOG=y
    CONFIG_MSM_RPC_PING=y
    CONFIG_MSM_RPC_PROC_COMM_TEST=y
    CONFIG_MSM_RPC_OEM_RAPI=y
    CONFIG_MSM_RPCSERVER_HANDSET=y
    # CONFIG_MSM_RMT_STORAGE_CLIENT is not set
    CONFIG_MSM_DALRPC=y
    CONFIG_MSM_DALRPC_TEST=m
    # CONFIG_MSM_CPU_FREQ_SET_MIN_MAX is not set
    # CONFIG_SCALING_MAX_CPUFREQ_245760 is not set
    # CONFIG_SCALING_MAX_CPUFREQ_384000 is not set
    # CONFIG_SCALING_MAX_CPUFREQ_576000 is not set
    CONFIG_SCALING_MAX_CPUFREQ_768000=y
    # CONFIG_SCALING_MAX_CPUFREQ_998400 is not set
    CONFIG_SCALING_MAX_CPUFREQ=768000
    # CONFIG_MSM_CPU_AVS is not set
    # CONFIG_MSM_HW3D is not set
    CONFIG_AMSS_7X25_VERSION_2009=y
    # CONFIG_AMSS_7X25_VERSION_2008 is not set
    CONFIG_MSM_QDSP6=y
    # CONFIG_MSM_VREG_SWITCH_INVERTED is not set
    CONFIG_MSM_DMA_TEST=m
    # CONFIG_WIFI_CONTROL_FUNC is not set
    # CONFIG_QSD_AUDIO is not set
    # CONFIG_SURF_FFA_GPIO_KEYPAD is not set
    CONFIG_HID_GPIO_KEYPAD=y
    # CONFIG_CLOCK_BASED_SLEEP_LIMIT is not set
    CONFIG_MSM_SLEEP_TIME_OVERRIDE=y
    # CONFIG_MSM_MEMORY_LOW_POWER_MODE is not set
    CONFIG_MSM_PM_TIMEOUT_HALT=y
    # CONFIG_MSM_PM_TIMEOUT_RESET_MODEM is not set
    # CONFIG_MSM_PM_TIMEOUT_RESET_CHIP is not set
    # CONFIG_MSM_NPA is not set
    # CONFIG_MSM_DIRECT_SCLK_ACCESS is not set
    CONFIG_MSM7200A_TLMM=y
    # CONFIG_HUAWEI_MSM_VIBRATOR is not set
    # Processor Type
    CONFIG_CPU_32=y
    CONFIG_CPU_32v6K=y
    CONFIG_CPU_V7=y
    CONFIG_CPU_32v7=y
    CONFIG_CPU_ABRT_EV7=y
    CONFIG_CPU_PABRT_V7=y
    CONFIG_CPU_CACHE_V7=y
    CONFIG_CPU_CACHE_VIPT=y
    CONFIG_CPU_COPY_V6=y
    CONFIG_CPU_TLB_V7=y
    CONFIG_VERIFY_PERMISSION_FAULT=y
    CONFIG_CPU_HAS_ASID=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    # Processor Features
    CONFIG_ARM_THUMB=y
    # CONFIG_ARM_THUMBEE is not set
    # CONFIG_CPU_ICACHE_DISABLE is not set
    # CONFIG_CPU_DCACHE_DISABLE is not set
    # CONFIG_CPU_BPREDICT_DISABLE is not set
    CONFIG_HAS_TLS_REG=y
    CONFIG_ARM_L1_CACHE_SHIFT=5
    # CONFIG_VCM is not set
    # CONFIG_ARM_ERRATA_430973 is not set
    # CONFIG_ARM_ERRATA_458693 is not set
    # CONFIG_ARM_ERRATA_460075 is not set
    # Bus support
    # CONFIG_PCI_SYSCALL is not set
    # CONFIG_ARCH_SUPPORTS_MSI is not set
    # CONFIG_PCCARD is not set
    # CONFIG_KSAPI is not set
    # Kernel Features
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ=y
    CONFIG_HIGH_RES_TIMERS=y
    CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
    # CONFIG_VMSPLIT_3G is not set
    CONFIG_VMSPLIT_2G=y
    # CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0x80000000
    # CONFIG_PREEMPT_NONE is not set
    # CONFIG_PREEMPT_VOLUNTARY is not set
    CONFIG_PREEMPT=y
    CONFIG_HZ=100
    # CONFIG_THUMB2_KERNEL is not set
    CONFIG_AEABI=y
    CONFIG_OABI_COMPAT=y
    # CONFIG_HOLES_IN_ZONE is not set
    # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
    # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
    # CONFIG_HIGHMEM is not set
    CONFIG_VMALLOC_RESERVE=0x08000000
    CONFIG_SELECT_MEMORY_MODEL=y
    CONFIG_FLATMEM_MANUAL=y
    # CONFIG_DISCONTIGMEM_MANUAL is not set
    # CONFIG_SPARSEMEM_MANUAL is not set
    CONFIG_FLATMEM=y
    CONFIG_FLAT_NODE_MEM_MAP=y
    CONFIG_PAGEFLAGS_EXTENDED=y
    CONFIG_SPLIT_PTLOCK_CPUS=4
    # CONFIG_PHYS_ADDR_T_64BIT is not set
    CONFIG_ZONE_DMA_FLAG=0
    CONFIG_VIRT_TO_BUS=y
    CONFIG_HAVE_MLOCK=y
    CONFIG_HAVE_MLOCKED_PAGE_BIT=y
    # CONFIG_KSM is not set
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_ALIGNMENT_TRAP=y
    # CONFIG_UACCESS_WITH_MEMCPY is not set
    # Boot options
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_CMDLINE="init=/sbin/init root=/dev/ram rw initrd=0x11000000,16M console=ttyDCC0 mem=88M"
    # CONFIG_XIP_KERNEL is not set
    # CONFIG_KEXEC is not set
    # CPU Power Management
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_TABLE=y
    CONFIG_CPU_FREQ_DEBUG=y
    CONFIG_CPU_FREQ_STAT=y
    CONFIG_CPU_FREQ_STAT_DETAILS=y
    CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
    CONFIG_CPU_FREQ_GOV_POWERSAVE=y
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
    CONFIG_CPU_FREQ_GOV_ONDEMAND=y
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
    # CONFIG_CPU_IDLE is not set
    CONFIG_CPU_FREQ_MSM=y
    # Floating point emulation
    # At least one emulation must be selected
    # CONFIG_FPE_NWFPE is not set
    # CONFIG_FPE_FASTFPE is not set
    CONFIG_VFP=y
    CONFIG_VFPv3=y
    CONFIG_NEON=y
    # Userspace binary formats
    CONFIG_BINFMT_ELF=y
    # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
    CONFIG_HAVE_AOUT=y
    # CONFIG_BINFMT_AOUT is not set
    # CONFIG_BINFMT_MISC is not set
    # Power management options
    CONFIG_PM=y
    # CONFIG_PM_DEBUG is not set
    CONFIG_PM_SLEEP=y
    CONFIG_SUSPEND=y
    CONFIG_SUSPEND_FREEZER=y
    CONFIG_HAS_WAKELOCK=y
    CONFIG_HAS_EARLYSUSPEND=y
    CONFIG_WAKELOCK=y
    CONFIG_WAKELOCK_STAT=y
    CONFIG_USER_WAKELOCK=y
    CONFIG_EARLYSUSPEND=y
    # CONFIG_NO_USER_SPACE_SCREEN_ACCESS_CONTROL is not set
    CONFIG_CONSOLE_EARLYSUSPEND=y
    # CONFIG_FB_EARLYSUSPEND is not set
    # CONFIG_APM_EMULATION is not set
    # CONFIG_PM_RUNTIME is not set
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_NET=y
    # Networking options
    CONFIG_PACKET=y
    # CONFIG_PACKET_MMAP is not set
    CONFIG_UNIX=y
    CONFIG_XFRM=y
    # CONFIG_XFRM_USER is not set
    # CONFIG_XFRM_SUB_POLICY is not set
    CONFIG_XFRM_MIGRATE=y
    # CONFIG_XFRM_STATISTICS is not set
    CONFIG_XFRM_IPCOMP=y
    CONFIG_NET_KEY=y
    CONFIG_NET_KEY_MIGRATE=y
    CONFIG_INET=y
    CONFIG_IP_MULTICAST=y
    CONFIG_IP_ADVANCED_ROUTER=y
    CONFIG_ASK_IP_FIB_HASH=y
    # CONFIG_IP_FIB_TRIE is not set
    CONFIG_IP_FIB_HASH=y
    CONFIG_IP_MULTIPLE_TABLES=y
    CONFIG_IP_ROUTE_MULTIPATH=y
    CONFIG_IP_ROUTE_VERBOSE=y
    # CONFIG_IP_PNP is not set
    CONFIG_NET_IPIP=y
    CONFIG_NET_IPGRE=y
    CONFIG_NET_IPGRE_BROADCAST=y
    CONFIG_IP_MROUTE=y
    # CONFIG_IP_PIMSM_V1 is not set
    # CONFIG_IP_PIMSM_V2 is not set
    # CONFIG_ARPD is not set
    # CONFIG_SYN_COOKIES is not set
    CONFIG_INET_AH=y
    CONFIG_INET_ESP=y
    CONFIG_INET_IPCOMP=y
    CONFIG_INET_XFRM_TUNNEL=y
    CONFIG_INET_TUNNEL=y
    CONFIG_INET_XFRM_MODE_TRANSPORT=y
    CONFIG_INET_XFRM_MODE_TUNNEL=y
    CONFIG_INET_XFRM_MODE_BEET=y
    # CONFIG_INET_LRO is not set
    # CONFIG_INET_DIAG is not set
    # CONFIG_TCP_CONG_ADVANCED is not set
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    CONFIG_IPV6=y
    CONFIG_IPV6_PRIVACY=y
    CONFIG_IPV6_ROUTER_PREF=y
    # CONFIG_IPV6_ROUTE_INFO is not set
    CONFIG_IPV6_OPTIMISTIC_DAD=y
    CONFIG_INET6_AH=y
    CONFIG_INET6_ESP=y
    CONFIG_INET6_IPCOMP=y
    CONFIG_IPV6_MIP6=y
    CONFIG_INET6_XFRM_TUNNEL=y
    CONFIG_INET6_TUNNEL=y
    CONFIG_INET6_XFRM_MODE_TRANSPORT=y
    CONFIG_INET6_XFRM_MODE_TUNNEL=y
    CONFIG_INET6_XFRM_MODE_BEET=y
    # CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
    CONFIG_IPV6_SIT=y
    CONFIG_IPV6_NDISC_NODETYPE=y
    # CONFIG_IPV6_TUNNEL is not set
    # CONFIG_IPV6_MULTIPLE_TABLES is not set
    # CONFIG_IPV6_MROUTE is not set
    CONFIG_ANDROID_PARANOID_NETWORK=y
    # CONFIG_NETWORK_SECMARK is not set
    CONFIG_NETFILTER=y
    # CONFIG_NETFILTER_DEBUG is not set
    CONFIG_NETFILTER_ADVANCED=y
    # Core Netfilter Configuration
    CONFIG_NETFILTER_NETLINK=y
    CONFIG_NETFILTER_NETLINK_QUEUE=y
    CONFIG_NETFILTER_NETLINK_LOG=y
    CONFIG_NF_CONNTRACK=y
    CONFIG_NF_CT_ACCT=y
    CONFIG_NF_CONNTRACK_MARK=y
    # CONFIG_NF_CONNTRACK_EVENTS is not set
    # CONFIG_NF_CT_PROTO_DCCP is not set
    CONFIG_NF_CT_PROTO_GRE=y
    # CONFIG_NF_CT_PROTO_SCTP is not set
    # CONFIG_NF_CT_PROTO_UDPLITE is not set
    # CONFIG_NF_CONNTRACK_AMANDA is not set
    # CONFIG_NF_CONNTRACK_FTP is not set
    # CONFIG_NF_CONNTRACK_H323 is not set
    # CONFIG_NF_CONNTRACK_IRC is not set
    # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
    CONFIG_NF_CONNTRACK_PPTP=y
    # CONFIG_NF_CONNTRACK_SANE is not set
    # CONFIG_NF_CONNTRACK_SIP is not set
    # CONFIG_NF_CONNTRACK_TFTP is not set
    CONFIG_NF_CT_NETLINK=y
    CONFIG_NETFILTER_TPROXY=y
    CONFIG_NETFILTER_XTABLES=y
    CONFIG_NETFILTER_XT_TARGET_CLASSIFY=y
    CONFIG_NETFILTER_XT_TARGET_CONNMARK=y
    CONFIG_NETFILTER_XT_TARGET_DSCP=y
    CONFIG_NETFILTER_XT_TARGET_HL=y
    CONFIG_NETFILTER_XT_TARGET_MARK=y
    CONFIG_NETFILTER_XT_TARGET_NFLOG=y
    CONFIG_NETFILTER_XT_TARGET_NFQUEUE=y
    # CONFIG_NETFILTER_XT_TARGET_NOTRACK is not set
    CONFIG_NETFILTER_XT_TARGET_RATEEST=y
    CONFIG_NETFILTER_XT_TARGET_TPROXY=y
    CONFIG_NETFILTER_XT_TARGET_TRACE=y
    CONFIG_NETFILTER_XT_TARGET_TCPMSS=y
    CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP=y
    # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
    CONFIG_NETFILTER_XT_MATCH_COMMENT=y
    # CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set
    CONFIG_NETFILTER_XT_MATCH_DCCP=y
    CONFIG_NETFILTER_XT_MATCH_DSCP=y
    CONFIG_NETFILTER_XT_MATCH_ESP=y
    CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=y
    # CONFIG_NETFILTER_XT_MATCH_HELPER is not set
    CONFIG_NETFILTER_XT_MATCH_HL=y
    CONFIG_NETFILTER_XT_MATCH_IPRANGE=y
    CONFIG_NETFILTER_XT_MATCH_LENGTH=y
    CONFIG_NETFILTER_XT_MATCH_LIMIT=y
    CONFIG_NETFILTER_XT_MATCH_MAC=y
    CONFIG_NETFILTER_XT_MATCH_MARK=y
    CONFIG_NETFILTER_XT_MATCH_MULTIPORT=y
    CONFIG_NETFILTER_XT_MATCH_OWNER=y
    CONFIG_NETFILTER_XT_MATCH_POLICY=y
    CONFIG_NETFILTER_XT_MATCH_PKTTYPE=y
    CONFIG_NETFILTER_XT_MATCH_QUOTA=y
    CONFIG_NETFILTER_XT_MATCH_RATEEST=y
    CONFIG_NETFILTER_XT_MATCH_REALM=y
    CONFIG_NETFILTER_XT_MATCH_RECENT=y
    CONFIG_NETFILTER_XT_MATCH_RECENT_PROC_COMPAT=y
    CONFIG_NETFILTER_XT_MATCH_SCTP=y
    # CONFIG_NETFILTER_XT_MATCH_SOCKET is not set
    CONFIG_NETFILTER_XT_MATCH_STATE=y
    CONFIG_NETFILTER_XT_MATCH_STATISTIC=y
    # CONFIG_NETFILTER_XT_MATCH_STRING is not set
    CONFIG_NETFILTER_XT_MATCH_TCPMSS=y
    # CONFIG_NETFILTER_XT_MATCH_TIME is not set
    # CONFIG_NETFILTER_XT_MATCH_U32 is not set
    # CONFIG_NETFILTER_XT_MATCH_OSF is not set
    # CONFIG_IP_VS is not set
    # IP: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV4=y
    CONFIG_NF_CONNTRACK_IPV4=y
    CONFIG_NF_CONNTRACK_PROC_COMPAT=y
    CONFIG_IP_NF_QUEUE=y
    CONFIG_IP_NF_IPTABLES=y
    CONFIG_IP_NF_MATCH_ADDRTYPE=y
    CONFIG_IP_NF_MATCH_AH=y
    CONFIG_IP_NF_MATCH_ECN=y
    CONFIG_IP_NF_MATCH_TTL=y
    CONFIG_IP_NF_FILTER=y
    CONFIG_IP_NF_TARGET_REJECT=y
    CONFIG_IP_NF_TARGET_LOG=y
    CONFIG_IP_NF_TARGET_ULOG=y
    CONFIG_NF_NAT=y
    CONFIG_NF_NAT_NEEDED=y
    CONFIG_IP_NF_TARGET_MASQUERADE=y
    CONFIG_IP_NF_TARGET_NETMAP=y
    CONFIG_IP_NF_TARGET_REDIRECT=y
    CONFIG_NF_NAT_SNMP_BASIC=y
    CONFIG_NF_NAT_PROTO_GRE=y
    # CONFIG_NF_NAT_FTP is not set
    # CONFIG_NF_NAT_IRC is not set
    # CONFIG_NF_NAT_TFTP is not set
    # CONFIG_NF_NAT_AMANDA is not set
    CONFIG_NF_NAT_PPTP=y
    # CONFIG_NF_NAT_H323 is not set
    # CONFIG_NF_NAT_SIP is not set
    CONFIG_IP_NF_MANGLE=y
    CONFIG_IP_NF_TARGET_CLUSTERIP=y
    CONFIG_IP_NF_TARGET_ECN=y
    CONFIG_IP_NF_TARGET_TTL=y
    CONFIG_IP_NF_RAW=y
    CONFIG_IP_NF_ARPTABLES=y
    CONFIG_IP_NF_ARPFILTER=y
    CONFIG_IP_NF_ARP_MANGLE=y
    # IPv6: Netfilter Configuration
    # CONFIG_NF_CONNTRACK_IPV6 is not set
    # CONFIG_IP6_NF_QUEUE is not set
    # CONFIG_IP6_NF_IPTABLES is not set
    # CONFIG_IP_DCCP is not set
    # CONFIG_IP_SCTP is not set
    # CONFIG_RDS is not set
    # CONFIG_TIPC is not set
    # CONFIG_ATM is not set
    # CONFIG_BRIDGE is not set
    # CONFIG_NET_DSA is not set
    # CONFIG_VLAN_8021Q is not set
    # CONFIG_DECNET is not set
    # CONFIG_LLC2 is not set
    # CONFIG_IPX is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    # CONFIG_ECONET is not set
    # CONFIG_WAN_ROUTER is not set
    # CONFIG_PHONET is not set
    # CONFIG_IEEE802154 is not set
    # CONFIG_NET_SCHED is not set
    CONFIG_NET_CLS_ROUTE=y
    # CONFIG_DCB is not set
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # CONFIG_NET_DROP_MONITOR is not set
    # CONFIG_HAMRADIO is not set
    # CONFIG_CAN is not set
    # CONFIG_IRDA is not set
    CONFIG_BT=y
    CONFIG_BT_L2CAP=y
    CONFIG_BT_SCO=y
    CONFIG_BT_RFCOMM=y
    CONFIG_BT_RFCOMM_TTY=y
    CONFIG_BT_BNEP=y
    CONFIG_BT_BNEP_MC_FILTER=y
    CONFIG_BT_BNEP_PROTO_FILTER=y
    CONFIG_BT_HIDP=y
    # Bluetooth device drivers
    # CONFIG_BT_HCIBTUSB is not set
    # CONFIG_BT_HCIBTSDIO is not set
    CONFIG_BT_HCIUART=y
    CONFIG_BT_HCIUART_H4=y
    # CONFIG_BT_HCIUART_BCSP is not set
    CONFIG_BT_HCIUART_LL=y
    # CONFIG_BT_HCIUART_IBS is not set
    # CONFIG_BT_HCIBCM203X is not set
    # CONFIG_BT_HCIBPA10X is not set
    CONFIG_BT_MSM_SLEEP=y
    # CONFIG_BT_HCIBFUSB is not set
    # CONFIG_BT_HCIVHCI is not set
    # CONFIG_BT_MRVL is not set
    CONFIG_MSM_BT_POWER=y
    # CONFIG_AF_RXRPC is not set
    CONFIG_FIB_RULES=y
    CONFIG_WIRELESS=y
    CONFIG_CFG80211=y
    # CONFIG_NL80211_TESTMODE is not set
    # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
    # CONFIG_CFG80211_REG_DEBUG is not set
    CONFIG_CFG80211_DEFAULT_PS=y
    CONFIG_CFG80211_DEFAULT_PS_VALUE=1
    # CONFIG_CFG80211_DEBUGFS is not set
    CONFIG_WIRELESS_OLD_REGULATORY=y
    CONFIG_WIRELESS_EXT=y
    CONFIG_WIRELESS_EXT_SYSFS=y
    # CONFIG_LIB80211 is not set
    # CONFIG_MAC80211 is not set
    # CONFIG_WIMAX is not set
    CONFIG_RFKILL=y
    CONFIG_RFKILL_PM=y
    CONFIG_RFKILL_INPUT=y
    # CONFIG_NET_9P is not set
    # Device Drivers
    # Generic Driver Options
    CONFIG_UEVENT_HELPER_PATH=""
    # CONFIG_DEVTMPFS is not set
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    CONFIG_FW_LOADER=y
    CONFIG_FIRMWARE_IN_KERNEL=y
    CONFIG_EXTRA_FIRMWARE=""
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_SYS_HYPERVISOR is not set
    # CONFIG_CONNECTOR is not set
    CONFIG_MTD=y
    # CONFIG_MTD_DEBUG is not set
    CONFIG_MTD_TESTS=m
    # CONFIG_MTD_CONCAT is not set
    CONFIG_MTD_PARTITIONS=y
    # CONFIG_MTD_LAZYECCSTATS is not set
    # CONFIG_MTD_REDBOOT_PARTS is not set
    CONFIG_MTD_CMDLINE_PARTS=y
    # CONFIG_MTD_AFS_PARTS is not set
    # CONFIG_MTD_AR7_PARTS is not set
    # User Modules And Translation Layers
    CONFIG_MTD_CHAR=y
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
    # CONFIG_FTL is not set
    # CONFIG_NFTL is not set
    # CONFIG_INFTL is not set
    # CONFIG_RFD_FTL is not set
    # CONFIG_SSFDC is not set
    # CONFIG_MTD_OOPS is not set
    # RAM/ROM/Flash chip drivers
    # CONFIG_MTD_CFI is not set
    # CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
    # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
    # CONFIG_MTD_CFI_I4 is not set
    # CONFIG_MTD_CFI_I8 is not set
    # CONFIG_MTD_RAM is not set
    # CONFIG_MTD_ROM is not set
    # CONFIG_MTD_ABSENT is not set
    # Mapping drivers for chip access
    # CONFIG_MTD_COMPLEX_MAPPINGS is not set
    # CONFIG_MTD_PLATRAM is not set
    # Self-contained MTD device drivers
    CONFIG_MTD_MSM_NAND=y
    # CONFIG_MTD_DATAFLASH is not set
    # CONFIG_MTD_M25P80 is not set
    # CONFIG_MTD_SST25L is not set
    # CONFIG_MTD_SLRAM is not set
    # CONFIG_MTD_PHRAM is not set
    # CONFIG_MTD_MTDRAM is not set
    # CONFIG_MTD_BLOCK2MTD is not set
    # Disk-On-Chip Device Drivers
    # CONFIG_MTD_DOC2000 is not set
    # CONFIG_MTD_DOC2001 is not set
    # CONFIG_MTD_DOC2001PLUS is not set
    CONFIG_MTD_NAND_IDS=y
    # CONFIG_MTD_NAND is not set
    # CONFIG_MTD_ONENAND is not set
    # LPDDR flash memory drivers
    # CONFIG_MTD_LPDDR is not set
    # UBI - Unsorted block images
    # CONFIG_MTD_UBI is not set
    # CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_COW_COMMON is not set
    CONFIG_BLK_DEV_LOOP=y
    # CONFIG_BLK_DEV_CRYPTOLOOP is not set
    # CONFIG_BLK_DEV_NBD is not set
    # CONFIG_BLK_DEV_UB is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=8
    CONFIG_BLK_DEV_RAM_SIZE=16384
    # CONFIG_BLK_DEV_XIP is not set
    # CONFIG_CDROM_PKTCDVD is not set
    # CONFIG_ATA_OVER_ETH is not set
    CONFIG_MISC_DEVICES=y
    CONFIG_ANDROID_PMEM=y
    # CONFIG_ANDROID_PMEM_DEBUG is not set
    CONFIG_ANDROID_PMEM_KAPI_TEST=m
    # CONFIG_ICS932S401 is not set
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_KERNEL_DEBUGGER_CORE is not set
    # CONFIG_ISL29003 is not set
    CONFIG_UID_STAT=y
    # CONFIG_WL127X_RFKILL is not set
    # CONFIG_APANIC is not set
    # CONFIG_TSIF is not set
    # CONFIG_HAPTIC_ISA1200 is not set
    # CONFIG_C2PORT is not set
    # EEPROM support
    # CONFIG_EEPROM_AT24 is not set
    # CONFIG_EEPROM_AT25 is not set
    # CONFIG_EEPROM_LEGACY is not set
    # CONFIG_EEPROM_MAX6875 is not set
    # CONFIG_EEPROM_93CX6 is not set
    CONFIG_HAVE_IDE=y
    # CONFIG_IDE is not set
    # SCSI device support
    # CONFIG_RAID_ATTRS is not set
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    CONFIG_SCSI_TGT=y
    # CONFIG_SCSI_NETLINK is not set
    CONFIG_SCSI_PROC_FS=y
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    # CONFIG_CHR_DEV_OSST is not set
    # CONFIG_BLK_DEV_SR is not set
    CONFIG_CHR_DEV_SG=y
    CONFIG_CHR_DEV_SCH=y
    CONFIG_SCSI_MULTI_LUN=y
    CONFIG_SCSI_CONSTANTS=y
    CONFIG_SCSI_LOGGING=y
    CONFIG_SCSI_SCAN_ASYNC=y
    CONFIG_SCSI_WAIT_SCAN=m
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    # CONFIG_SCSI_ISCSI_ATTRS is not set
    # CONFIG_SCSI_SAS_LIBSAS is not set
    # CONFIG_SCSI_SRP_ATTRS is not set
    CONFIG_SCSI_LOWLEVEL=y
    # CONFIG_ISCSI_TCP is not set
    # CONFIG_LIBFC is not set
    # CONFIG_LIBFCOE is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_DH is not set
    # CONFIG_SCSI_OSD_INITIATOR is not set
    # CONFIG_ATA is not set
    CONFIG_MD=y
    # CONFIG_BLK_DEV_MD is not set
    CONFIG_BLK_DEV_DM=y
    # CONFIG_DM_DEBUG is not set
    CONFIG_DM_CRYPT=y
    CONFIG_DM_SNAPSHOT=y
    CONFIG_DM_MIRROR=y
    # CONFIG_DM_LOG_USERSPACE is not set
    CONFIG_DM_ZERO=y
    CONFIG_DM_MULTIPATH=y
    CONFIG_DM_MULTIPATH_QL=y
    CONFIG_DM_MULTIPATH_ST=y
    # CONFIG_DM_DELAY is not set
    # CONFIG_DM_UEVENT is not set
    CONFIG_NETDEVICES=y
    CONFIG_DUMMY=y
    # CONFIG_BONDING is not set
    # CONFIG_MACVLAN is not set
    # CONFIG_EQUALIZER is not set
    CONFIG_TUN=y
    # CONFIG_VETH is not set
    # CONFIG_PHYLIB is not set
    CONFIG_NET_ETHERNET=y
    # CONFIG_MII is not set
    # CONFIG_AX88796 is not set
    # CONFIG_SMC91X is not set
    # CONFIG_DM9000 is not set
    # CONFIG_ENC28J60 is not set
    # CONFIG_ETHOC is not set
    # CONFIG_SMC911X is not set
    # CONFIG_SMSC911X is not set
    # CONFIG_DNET is not set
    # CONFIG_IBM_NEW_EMAC_ZMII is not set
    # CONFIG_IBM_NEW_EMAC_RGMII is not set
    # CONFIG_IBM_NEW_EMAC_TAH is not set
    # CONFIG_IBM_NEW_EMAC_EMAC4 is not set
    # CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
    # CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
    # CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
    # CONFIG_B44 is not set
    # CONFIG_KS8842 is not set
    # CONFIG_KS8851 is not set
    # CONFIG_KS8851_MLL is not set
    # CONFIG_NETDEV_1000 is not set
    # CONFIG_NETDEV_10000 is not set
    CONFIG_WLAN=y
    # CONFIG_WLAN_PRE80211 is not set
    # CONFIG_WLAN_80211 is not set
    CONFIG_LIBRA_SDIOIF=m
    # CONFIG_BCM4329 is not set
    # Enable WiMAX (Networking options) to see the WiMAX drivers
    # USB Network Adapters
    # CONFIG_USB_CATC is not set
    # CONFIG_USB_KAWETH is not set
    # CONFIG_USB_PEGASUS is not set
    # CONFIG_USB_RTL8150 is not set
    # CONFIG_USB_USBNET is not set
    # CONFIG_USB_HSO is not set
    # CONFIG_WAN is not set
    CONFIG_PPP=y
    CONFIG_PPP_MULTILINK=y
    CONFIG_PPP_FILTER=y
    CONFIG_PPP_ASYNC=y
    CONFIG_PPP_SYNC_TTY=y
    CONFIG_PPP_DEFLATE=y
    CONFIG_PPP_BSDCOMP=y
    CONFIG_PPP_MPPE=y
    CONFIG_PPPOE=y
    CONFIG_PPPOL2TP=y
    CONFIG_PPPOLAC=y
    CONFIG_PPPOPNS=y
    CONFIG_SLIP=y
    CONFIG_SLIP_COMPRESSED=y
    CONFIG_SLHC=y
    # CONFIG_SLIP_SMART is not set
    CONFIG_SLIP_MODE_SLIP6=y
    # CONFIG_NETCONSOLE is not set
    CONFIG_MSM_RMNET=y
    # CONFIG_MSM_RMNET_DEBUG is not set
    # CONFIG_NETPOLL is not set
    # CONFIG_NET_POLL_CONTROLLER is not set
    # CONFIG_ISDN is not set
    # CONFIG_PHONE is not set
    # Input device support
    CONFIG_INPUT=y
    # CONFIG_INPUT_FF_MEMLESS is not set
    # CONFIG_INPUT_POLLDEV is not set
    # Userland interfaces
    # CONFIG_INPUT_MOUSEDEV is not set
    # CONFIG_INPUT_JOYDEV is not set
    CONFIG_INPUT_EVDEV=y
    CONFIG_INPUT_EVBUG=m
    # CONFIG_INPUT_KEYRESET is not set
    # Input Device Drivers
    # CONFIG_INPUT_KEYBOARD is not set
    CONFIG_INPUT_MOUSE=y
    # CONFIG_MOUSE_PS2 is not set
    # CONFIG_MOUSE_SERIAL is not set
    # CONFIG_MOUSE_APPLETOUCH is not set
    # CONFIG_MOUSE_BCM5974 is not set
    # CONFIG_MOUSE_VSXXXAA is not set
    CONFIG_MOUSE_OFN_HID=y
    # CONFIG_MOUSE_GPIO is not set
    # CONFIG_MOUSE_SYNAPTICS_I2C is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    CONFIG_INPUT_TOUCHSCREEN=y
    # CONFIG_TOUCHSCREEN_ADS7846 is not set
    # CONFIG_TOUCHSCREEN_AD7877 is not set
    # CONFIG_TOUCHSCREEN_AD7879_I2C is not set
    # CONFIG_TOUCHSCREEN_AD7879_SPI is not set
    # CONFIG_TOUCHSCREEN_AD7879 is not set
    # CONFIG_TOUCHSCREEN_CYPRESS_TMG is not set
    # CONFIG_TOUCHSCREEN_EETI is not set
    # CONFIG_TOUCHSCREEN_FUJITSU is not set
    # CONFIG_TOUCHSCREEN_GUNZE is not set
    # CONFIG_TOUCHSCREEN_ELAN_I2C_8232 is not set
    # CONFIG_TOUCHSCREEN_ELO is not set
    # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
    # CONFIG_TOUCHSCREEN_MCS5000 is not set
    # CONFIG_TOUCHSCREEN_MTOUCH is not set
    # CONFIG_TOUCHSCREEN_INEXIO is not set
    # CONFIG_TOUCHSCREEN_MK712 is not set
    # CONFIG_TOUCHSCREEN_PENMOUNT is not set
    # CONFIG_TOUCHSCREEN_T1320 is not set
    # CONFIG_TOUCHSCREEN_MXT224 is not set
    # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
    # CONFIG_TOUCHSCREEN_TOUCHWIN is not set
    # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
    # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
    # CONFIG_TOUCHSCREEN_TSC2007 is not set
    CONFIG_TOUCHSCREEN_MSM_LEGACY=y
    # CONFIG_ANDROID_TOUCHSCREEN_MSM_HACKS is not set
    # CONFIG_TOUCHSCREEN_CY8C_TS is not set
    CONFIG_INPUT_ACCELEROMETER=y
    CONFIG_ACCELEROMETER_ADXL345=y
    CONFIG_ACCELEROMETER_ST_L1S35DE=y
    # CONFIG_ACCELEROMETER_MMA7455L is not set
    CONFIG_INPUT_MISC=y
    # CONFIG_INPUT_ATI_REMOTE is not set
    # CONFIG_INPUT_ATI_REMOTE2 is not set
    CONFIG_INPUT_KEYCHORD=y
    # CONFIG_INPUT_KEYSPAN_REMOTE is not set
    # CONFIG_INPUT_POWERMATE is not set
    # CONFIG_INPUT_YEALINK is not set
    # CONFIG_INPUT_CM109 is not set
    CONFIG_INPUT_UINPUT=y
    CONFIG_INPUT_GPIO=y
    # CONFIG_INPUT_CAPELLA_CM3602 is not set
    # CONFIG_INPUT_PEDESTAL is not set
    CONFIG_INPUT_CYPRESS120_I2C_TS=y
    CONFIG_CYPRESS120=y
    # CONFIG_DOCK_DET is not set
  6. Jota
    Jota Member
    BH, Brazil
    Ideos S7_105
    # Hardware I/O ports
    CONFIG_SERIO=y
    CONFIG_SERIO_SERPORT=y
    # CONFIG_SERIO_LIBPS2 is not set
    # CONFIG_SERIO_RAW is not set
    # CONFIG_GAMEPORT is not set
    # Character devices
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_HW_CONSOLE=y
    # CONFIG_VT_HW_CONSOLE_BINDING is not set
    CONFIG_DEVMEM=y
    CONFIG_DEVKMEM=y
    # CONFIG_SERIAL_NONSTANDARD is not set
    # Serial drivers
    # CONFIG_SERIAL_8250 is not set
    # Non-8250 serial port support
    # CONFIG_SERIAL_MAX3100 is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    CONFIG_SERIAL_MSM=y
    CONFIG_SERIAL_MSM_CONSOLE=y
    CONFIG_SERIAL_MSM_CLOCK_CONTROL=y
    # CONFIG_SERIAL_MSM_RX_WAKEUP is not set
    # CONFIG_SERIAL_MSM_HSL is not set
    CONFIG_SERIAL_MSM_HS=y
    # CONFIG_SERIAL_BCM_BT_LPM is not set
    # Diag Support
    CONFIG_DIAG_CHAR=y
    CONFIG_UNIX98_PTYS=y
    # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
    # CONFIG_LEGACY_PTYS is not set
    # CONFIG_IPMI_HANDLER is not set
    # CONFIG_HW_RANDOM is not set
    # CONFIG_R3964 is not set
    # CONFIG_RAW_DRIVER is not set
    # CONFIG_TCG_TPM is not set
    # CONFIG_DCC_TTY is not set
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    CONFIG_I2C_HELPER_AUTO=y
    # I2C Hardware Bus support
    # I2C system bus drivers (mostly embedded / system-on-chip)
    # CONFIG_I2C_GPIO is not set
    CONFIG_I2C_MSM=y
    # CONFIG_GPIO_I2C_ADPT is not set
    # CONFIG_I2C_OCORES is not set
    # CONFIG_I2C_SIMTEC is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_PARPORT_LIGHT is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_STUB is not set
    # Miscellaneous I2C Chip support
    # CONFIG_DS1682 is not set
    # CONFIG_SENSORS_TSL2550 is not set
    # CONFIG_SENSORS_AKM8976 is not set
    CONFIG_SENSORS_AKM8973=y
    # CONFIG_SENSORS_PCA963X is not set
    # CONFIG_SENSORS_MT9T013 is not set
    # CONFIG_VP_A1026 is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    # CONFIG_I2C_DEBUG_CHIP is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_BITBANG is not set
    # CONFIG_SPI_GPIO is not set
    # CONFIG_SPI_QSD is not set
    # SPI Protocol Masters
    # CONFIG_SPI_SPIDEV is not set
    # CONFIG_SPI_TLE62X0 is not set
    # PPS support
    # CONFIG_PPS is not set
    CONFIG_ARCH_WANT_OPTIONAL_GPIOLIB=y
    # CONFIG_GPIOLIB is not set
    # CONFIG_W1 is not set
    CONFIG_POWER_SUPPLY=y
    # CONFIG_POWER_SUPPLY_DEBUG is not set
    # CONFIG_PDA_POWER is not set
    # CONFIG_BATTERY_DS2760 is not set
    # CONFIG_BATTERY_DS2782 is not set
    # CONFIG_BATTERY_DS2784 is not set
    # CONFIG_BATTERY_BQ27x00 is not set
    # CONFIG_BATTERY_BQ275X0 is not set
    # CONFIG_BATTERY_MAX17040 is not set
    CONFIG_BATTERY_MSM=y
    # CONFIG_BATTERY_MSM_FAKE is not set
    CONFIG_LIGHT_SENSOR_PO188=y
    # CONFIG_HWMON is not set
    # CONFIG_THERMAL is not set
    # CONFIG_WATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    # Sonics Silicon Backplane
    # CONFIG_SSB is not set
    # Multifunction device drivers
    # CONFIG_MFD_CORE is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_HTC_PASIC3 is not set
    CONFIG_TPS65023=y
    # CONFIG_TWL4030_CORE is not set
    # CONFIG_MFD_TMIO is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM831X is not set
    # CONFIG_MFD_WM8350_I2C is not set
    # CONFIG_MFD_PCF50633 is not set
    # CONFIG_MFD_MC13783 is not set
    # CONFIG_AB3100_CORE is not set
    # CONFIG_EZX_PCAP is not set
    # CONFIG_REGULATOR is not set
    CONFIG_MEDIA_SUPPORT=y
    # Multimedia core support
    CONFIG_VIDEO_DEV=y
    CONFIG_VIDEO_V4L2_COMMON=y
    CONFIG_VIDEO_ALLOW_V4L1=y
    CONFIG_VIDEO_V4L1_COMPAT=y
    # CONFIG_DVB_CORE is not set
    CONFIG_VIDEO_MEDIA=y
    # Multimedia drivers
    # CONFIG_MEDIA_ATTACH is not set
    CONFIG_MEDIA_TUNER=y
    # CONFIG_MEDIA_TUNER_CUSTOMISE is not set
    CONFIG_MEDIA_TUNER_SIMPLE=y
    CONFIG_MEDIA_TUNER_TDA8290=y
    CONFIG_MEDIA_TUNER_TDA9887=y
    CONFIG_MEDIA_TUNER_TEA5761=y
    CONFIG_MEDIA_TUNER_TEA5767=y
    CONFIG_MEDIA_TUNER_MT20XX=y
    CONFIG_MEDIA_TUNER_XC2028=y
    CONFIG_MEDIA_TUNER_XC5000=y
    CONFIG_MEDIA_TUNER_MC44S803=y
    CONFIG_VIDEO_V4L2=y
    CONFIG_VIDEO_V4L1=y
    CONFIG_VIDEO_CAPTURE_DRIVERS=y
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    CONFIG_VIDEO_HELPER_CHIPS_AUTO=y
    # CONFIG_VIDEO_VIVI is not set
    # CONFIG_VIDEO_CPIA is not set
    # CONFIG_VIDEO_CPIA2 is not set
    # CONFIG_VIDEO_SAA5246A is not set
    # CONFIG_VIDEO_SAA5249 is not set
    # CONFIG_SOC_CAMERA is not set
    # CONFIG_V4L_USB_DRIVERS is not set
    # Qualcomm MSM Camera And Video
    CONFIG_MSM_CAMERA=y
    # CONFIG_MSM_CAMERA_DEBUG is not set
    CONFIG_MSM_CAMERA_POWER_OFF_WHEN_LP=y
    # Camera Sensor Selection
    CONFIG_HUAWEI_CAMERA=y
    # CONFIG_MT9T013 is not set
    # CONFIG_MT9D112 is not set
    CONFIG_MT9D113_BACK=y
    CONFIG_MT9D113=y
    # CONFIG_OV2650 is not set
    # CONFIG_S5K5CAG is not set
    # CONFIG_MT9V114 is not set
    # CONFIG_MT9P012 is not set
    # CONFIG_MT9P012_KM is not set
    # CONFIG_S5K3E2FX is not set
    # CONFIG_VB6801 is not set
    CONFIG_MSM_CAMERA_FLASH=y
    # CONFIG_MSM_GEMINI is not set
    CONFIG_RADIO_ADAPTERS=y
    # CONFIG_I2C_SI4713 is not set
    # CONFIG_RADIO_SI4713 is not set
    # CONFIG_USB_DSBR is not set
    # CONFIG_RADIO_SI470X is not set
    # CONFIG_USB_MR800 is not set
    # CONFIG_RADIO_TEA5764 is not set
    # CONFIG_DAB is not set
    # Graphics support
    # CONFIG_DRM is not set
    CONFIG_MSM_KGSL=y
    # CONFIG_MSM_KGSL_2D is not set
    CONFIG_MSM_KGSL_MMU=y
    # CONFIG_KGSL_PER_PROCESS_PAGE_TABLE is not set
    CONFIG_MSM_KGSL_MMU_PAGE_FAULT=y
    # CONFIG_VGASTATE is not set
    CONFIG_VIDEO_OUTPUT_CONTROL=y
    CONFIG_FB=y
    # CONFIG_FIRMWARE_EDID is not set
    # CONFIG_FB_DDC is not set
    # CONFIG_FB_BOOT_VESA_SUPPORT is not set
    CONFIG_FB_CFB_FILLRECT=y
    CONFIG_FB_CFB_COPYAREA=y
    CONFIG_FB_CFB_IMAGEBLIT=y
    # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
    # CONFIG_FB_SYS_FILLRECT is not set
    # CONFIG_FB_SYS_COPYAREA is not set
    # CONFIG_FB_SYS_IMAGEBLIT is not set
    # CONFIG_FB_FOREIGN_ENDIAN is not set
    # CONFIG_FB_SYS_FOPS is not set
    # CONFIG_FB_SVGALIB is not set
    # CONFIG_FB_MACMODES is not set
    # CONFIG_FB_BACKLIGHT is not set
    CONFIG_FB_MODE_HELPERS=y
    CONFIG_FB_TILEBLITTING=y
    # Frame buffer hardware drivers
    # CONFIG_FB_S1D13XXX is not set
    # CONFIG_FB_VIRTUAL is not set
    # CONFIG_FB_METRONOME is not set
    # CONFIG_FB_MB862XX is not set
    CONFIG_FB_MSM=y
    # CONFIG_FB_MSM_BACKLIGHT is not set
    CONFIG_FB_MSM_LOGO=y
    CONFIG_FB_MSM_LCDC_HW=y
    # CONFIG_FB_MSM_MDP22 is not set
    # CONFIG_FB_MSM_MDP30 is not set
    CONFIG_FB_MSM_MDP31=y
    # CONFIG_FB_MSM_MDP40 is not set
    # CONFIG_FB_MSM_EBI2 is not set
    # CONFIG_FB_MSM_MDDI is not set
    CONFIG_FB_MSM_LCDC=y
    # CONFIG_FB_MSM_EXTMDDI is not set
    CONFIG_FB_MSM_TVOUT=y
    # CONFIG_FB_MSM_MDDI_TOSHIBA_COMMON is not set
    # CONFIG_FB_MSM_MDDI_TOSHIBA_COMMON_VGA is not set
    # CONFIG_FB_MSM_MDDI_ORISE is not set
    # CONFIG_FB_MSM_MDDI_AUTO_DETECT is not set
    CONFIG_FB_MSM_LCDC_PANEL=y
    # CONFIG_FB_MSM_LCDC_ST15_WXGA is not set
    # CONFIG_FB_MSM_LCDC_ST15_PANEL is not set
    CONFIG_FB_MSM_LCDC_PRISM_WVGA=y
    # CONFIG_FB_MSM_LCDC_SAMSUNG_WSVGA is not set
    # CONFIG_FB_MSM_LCDC_GORDON_VGA is not set
    # CONFIG_FB_MSM_LCDC_TOSHIBA_WVGA_PT is not set
    # CONFIG_FB_MSM_LCDC_SHARP_WVGA_PT is not set
    # CONFIG_FB_MSM_LCDC_WXGA is not set
    CONFIG_FB_MSM_LCDC_PRISM_WVGA_PANEL=y
    # CONFIG_FB_MSM_LCDC_SAMSUNG_WSVGA_PANEL is not set
    # CONFIG_FB_MSM_LCDC_GORDON_VGA_PANEL is not set
    # CONFIG_FB_MSM_LCDC_TOSHIBA_WVGA_PT_PANEL is not set
    # CONFIG_FB_MSM_LCDC_SHARP_WVGA_PT_PANEL is not set
    # CONFIG_FB_MSM_TRY_MDDI_CATCH_LCDC_PRISM is not set
    # CONFIG_FB_MSM_MDDI_PANEL_AUTO_DETECT is not set
    # CONFIG_FB_MSM_MDDI_PRISM_WVGA is not set
    # CONFIG_FB_MSM_MDDI_TOSHIBA_WVGA_PORTRAIT is not set
    # CONFIG_FB_MSM_MDDI_TOSHIBA_VGA is not set
    # CONFIG_FB_MSM_MDDI_TOSHIBA_WVGA is not set
    # CONFIG_FB_MSM_MDDI_SHARP_QVGA_128x128 is not set
    # CONFIG_FB_MSM_EBI2_TMD_QVGA_EPSON_QCIF is not set
    # CONFIG_FB_MSM_PANEL_NONE is not set
    # CONFIG_FB_MSM_LCDC_EXTERNAL_WXGA is not set
    # CONFIG_FB_MSM_HDMI_SII_EXTERNAL_720P is not set
    CONFIG_FB_MSM_SECONDARY_PANEL_NONE=y
    # CONFIG_FB_MSM_TVOUT_NTSC is not set
    CONFIG_FB_MSM_TVOUT_PAL=y
    # CONFIG_FB_MSM_TVOUT_NTSC_M is not set
    # CONFIG_FB_MSM_TVOUT_NTSC_J is not set
    # CONFIG_FB_MSM_TVOUT_PAL_BDGHIN is not set
    CONFIG_FB_MSM_TVOUT_PAL_M=y
    # CONFIG_FB_MSM_TVOUT_PAL_N is not set
    # CONFIG_FB_MSM_TVOUT_NONE is not set
    # CONFIG_FB_MSM_TVOUT_SVIDEO is not set
    # CONFIG_FB_MSM_DEFAULT_DEPTH_RGB565 is not set
    # CONFIG_FB_MSM_DEFAULT_DEPTH_ARGB8888 is not set
    CONFIG_FB_MSM_DEFAULT_DEPTH_RGBA8888=y
    # CONFIG_FB_BROADSHEET is not set
    # CONFIG_MSM_HDMI is not set
    CONFIG_BACKLIGHT_LCD_SUPPORT=y
    CONFIG_LCD_CLASS_DEVICE=y
    # CONFIG_LCD_LMS283GF05 is not set
    # CONFIG_LCD_LTV350QV is not set
    # CONFIG_LCD_ILI9320 is not set
    # CONFIG_LCD_TDO24M is not set
    # CONFIG_LCD_VGG2432A4 is not set
    # CONFIG_LCD_PLATFORM is not set
    CONFIG_BACKLIGHT_CLASS_DEVICE=y
    # CONFIG_BACKLIGHT_GENERIC is not set
    # Display device support
    # CONFIG_DISPLAY_SUPPORT is not set
    # Console display driver support
    # CONFIG_VGA_CONSOLE is not set
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE=y
    # CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY is not set
    # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
    # CONFIG_FONTS is not set
    CONFIG_FONT_8x8=y
    CONFIG_FONT_8x16=y
    # CONFIG_LOGO is not set
    CONFIG_SOUND=y
    # CONFIG_SOUND_OSS_CORE is not set
    CONFIG_SND=y
    # CONFIG_SND_SEQUENCER is not set
    # CONFIG_SND_MIXER_OSS is not set
    # CONFIG_SND_PCM_OSS is not set
    # CONFIG_SND_HRTIMER is not set
    # CONFIG_SND_DYNAMIC_MINORS is not set
    CONFIG_SND_SUPPORT_OLD_API=y
    CONFIG_SND_VERBOSE_PROCFS=y
    # CONFIG_SND_VERBOSE_PRINTK is not set
    # CONFIG_SND_DEBUG is not set
    # CONFIG_SND_RAWMIDI_SEQ is not set
    # CONFIG_SND_OPL3_LIB_SEQ is not set
    # CONFIG_SND_OPL4_LIB_SEQ is not set
    # CONFIG_SND_SBAWE_SEQ is not set
    # CONFIG_SND_EMU10K1_SEQ is not set
    # CONFIG_SND_DRIVERS is not set
    # CONFIG_SND_ARM is not set
    # CONFIG_SND_SPI is not set
    # CONFIG_SND_USB is not set
    # CONFIG_SND_SOC is not set
    # CONFIG_SOUND_PRIME is not set
    CONFIG_HID_SUPPORT=y
    CONFIG_HID=y
    # CONFIG_HIDRAW is not set
    # USB Input Devices
    CONFIG_USB_HID=y
    # CONFIG_HID_PID is not set
    # CONFIG_USB_HIDDEV is not set
    # Special HID drivers
    # CONFIG_HID_A4TECH is not set
    # CONFIG_HID_APPLE is not set
    # CONFIG_HID_BELKIN is not set
    # CONFIG_HID_CHERRY is not set
    # CONFIG_HID_CHICONY is not set
    # CONFIG_HID_CYPRESS is not set
    # CONFIG_HID_DRAGONRISE is not set
    # CONFIG_HID_EZKEY is not set
    # CONFIG_HID_KYE is not set
    # CONFIG_HID_GYRATION is not set
    # CONFIG_HID_TWINHAN is not set
    # CONFIG_HID_KENSINGTON is not set
    # CONFIG_HID_LOGITECH is not set
    # CONFIG_HID_MICROSOFT is not set
    # CONFIG_HID_MONTEREY is not set
    # CONFIG_HID_NTRIG is not set
    # CONFIG_HID_PANTHERLORD is not set
    # CONFIG_HID_PETALYNX is not set
    # CONFIG_HID_SAMSUNG is not set
    # CONFIG_HID_SONY is not set
    # CONFIG_HID_SUNPLUS is not set
    # CONFIG_HID_GREENASIA is not set
    # CONFIG_HID_SMARTJOYPLUS is not set
    # CONFIG_HID_TOPSEED is not set
    # CONFIG_HID_THRUSTMASTER is not set
    # CONFIG_HID_WACOM is not set
    # CONFIG_HID_ZEROPLUS is not set
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_ARCH_HAS_HCD=y
    # CONFIG_USB_ARCH_HAS_OHCI is not set
    CONFIG_USB_ARCH_HAS_EHCI=y
    CONFIG_USB=y
    # CONFIG_USB_DEBUG is not set
    CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
    # Miscellaneous USB options
    # CONFIG_USB_DEVICEFS is not set
    CONFIG_USB_DEVICE_CLASS=y
    # CONFIG_USB_DYNAMIC_MINORS is not set
    CONFIG_USB_SUSPEND=y
    CONFIG_USB_OTG=y
    # CONFIG_USB_OTG_WHITELIST is not set
    # CONFIG_USB_OTG_BLACKLIST_HUB is not set
    # CONFIG_USB_MON is not set
    # CONFIG_USB_WUSB is not set
    # CONFIG_USB_WUSB_CBAF is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    CONFIG_USB_EHCI_HCD=y
    CONFIG_USB_EHCI_EHSET=y
    CONFIG_USB_EHCI_ROOT_HUB_TT=y
    # CONFIG_USB_EHCI_TT_NEWSCHED is not set
    # CONFIG_USB_OXU210HP_HCD is not set
    CONFIG_USB_EHCI_MSM=y
    # CONFIG_USB_FS_HOST is not set
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_ISP1760_HCD is not set
    # CONFIG_USB_ISP1362_HCD is not set
    # CONFIG_USB_SL811_HCD is not set
    # CONFIG_USB_R8A66597_HCD is not set
    # CONFIG_USB_HWA_HCD is not set
    # CONFIG_USB_MUSB_HDRC is not set
    # CONFIG_USB_GADGET_MUSB_HDRC is not set
    # USB Device Class drivers
    CONFIG_USB_ACM=y
    # CONFIG_USB_PRINTER is not set
    # CONFIG_USB_WDM is not set
    # CONFIG_USB_TMC is not set
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
    # also be needed; see USB_STORAGE Help for more info
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_STORAGE_DEBUG is not set
    CONFIG_USB_STORAGE_DATAFAB=y
    CONFIG_USB_STORAGE_FREECOM=y
    CONFIG_USB_STORAGE_ISD200=y
    CONFIG_USB_STORAGE_USBAT=y
    CONFIG_USB_STORAGE_SDDR09=y
    CONFIG_USB_STORAGE_SDDR55=y
    CONFIG_USB_STORAGE_JUMPSHOT=y
    CONFIG_USB_STORAGE_ALAUDA=y
    CONFIG_USB_STORAGE_ONETOUCH=y
    CONFIG_USB_STORAGE_KARMA=y
    CONFIG_USB_STORAGE_CYPRESS_ATACB=y
    # CONFIG_USB_LIBUSUAL is not set
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    # USB port drivers
    # CONFIG_USB_SERIAL is not set
    # USB Miscellaneous drivers
    # CONFIG_USB_EMI62 is not set
    # CONFIG_USB_EMI26 is not set
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_RIO500 is not set
    # CONFIG_USB_LEGOTOWER is not set
    # CONFIG_USB_LCD is not set
    # CONFIG_USB_BERRY_CHARGE is not set
    # CONFIG_USB_LED is not set
    # CONFIG_USB_CYPRESS_CY7C63 is not set
    # CONFIG_USB_CYTHERM is not set
    # CONFIG_USB_IDMOUSE is not set
    # CONFIG_USB_FTDI_ELAN is not set
    # CONFIG_USB_APPLEDISPLAY is not set
    # CONFIG_USB_SISUSBVGA is not set
    # CONFIG_USB_LD is not set
    # CONFIG_USB_TRANCEVIBRATOR is not set
    # CONFIG_USB_IOWARRIOR is not set
    # CONFIG_USB_TEST is not set
    CONFIG_USB_EHSET_TEST_FIXTURE=y
    # CONFIG_USB_ISIGHTFW is not set
    # CONFIG_USB_VST is not set
    CONFIG_USB_GADGET=y
    # CONFIG_USB_GADGET_DEBUG is not set
    # CONFIG_USB_GADGET_DEBUG_FILES is not set
    # CONFIG_USB_GADGET_DEBUG_FS is not set
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_SELECTED=y
    # CONFIG_USB_AUTO_INSTALL is not set
    # CONFIG_USB_GADGET_AT91 is not set
    # CONFIG_USB_GADGET_ATMEL_USBA is not set
    # CONFIG_USB_GADGET_FSL_USB2 is not set
    # CONFIG_USB_GADGET_LH7A40X is not set
    # CONFIG_USB_GADGET_OMAP is not set
    # CONFIG_USB_GADGET_PXA25X is not set
    # CONFIG_USB_GADGET_R8A66597 is not set
    # CONFIG_USB_GADGET_PXA27X is not set
    # CONFIG_USB_GADGET_S3C_HSOTG is not set
    # CONFIG_USB_GADGET_IMX is not set
    # CONFIG_USB_GADGET_S3C2410 is not set
    # CONFIG_USB_GADGET_M66592 is not set
    # CONFIG_USB_GADGET_AMD5536UDC is not set
    # CONFIG_USB_GADGET_FSL_QE is not set
    # CONFIG_USB_GADGET_CI13XXX is not set
    # CONFIG_USB_GADGET_NET2280 is not set
    # CONFIG_USB_GADGET_GOKU is not set
    # CONFIG_USB_GADGET_LANGWELL is not set
    CONFIG_USB_GADGET_MSM_72K=y
    CONFIG_USB_MSM_72K=y
    # CONFIG_USB_GADGET_DUMMY_HCD is not set
    CONFIG_USB_GADGET_DUALSPEED=y
    # CONFIG_USB_ZERO is not set
    # CONFIG_USB_AUDIO is not set
    # CONFIG_USB_ETH is not set
    # CONFIG_USB_GADGETFS is not set
    # CONFIG_USB_FILE_STORAGE is not set
    # CONFIG_USB_G_SERIAL is not set
    # CONFIG_USB_MIDI_GADGET is not set
    # CONFIG_USB_G_PRINTER is not set
    CONFIG_USB_ANDROID=y
    CONFIG_USB_ANDROID_DIAG=y
    CONFIG_USB_ANDROID_CDC_ECM=y
    CONFIG_USB_ANDROID_RNDIS=y
    CONFIG_USB_ANDROID_RNDIS_WCEIS=y
    CONFIG_USB_ANDROID_RMNET=y
    CONFIG_RMNET_SMD_CTL_CHANNEL="DATA7_CNTL"
    CONFIG_RMNET_SMD_DATA_CHANNEL="DATA7"
    CONFIG_USB_F_SERIAL=y
    CONFIG_MODEM_SUPPORT=y
    CONFIG_USB_CSW_HACK=y
    # CONFIG_USB_CDC_COMPOSITE is not set
    # OTG and related infrastructure
    CONFIG_USB_OTG_UTILS=y
    # CONFIG_USB_GPIO_VBUS is not set
    CONFIG_USB_MSM_OTG_72K=y
    # CONFIG_NOP_USB_XCEIV is not set
    CONFIG_MMC=y
    # CONFIG_MMC_DEBUG is not set
    # CONFIG_MMC_PERF_PROFILING is not set
    # CONFIG_MMC_UNSAFE_RESUME is not set
    # CONFIG_MMC_EMBEDDED_SDIO is not set
    CONFIG_MMC_PARANOID_SD_INIT=y
    # MMC/SD/SDIO Card Drivers
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_BOUNCE=y
    # CONFIG_MMC_BLOCK_DEFERRED_RESUME is not set
    # CONFIG_SDIO_UART is not set
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_SDHCI is not set
    # CONFIG_MMC_AT91 is not set
    # CONFIG_MMC_ATMELMCI is not set
    # CONFIG_MMC_SPI is not set
    CONFIG_MMC_MSM=y
    CONFIG_MMC_MSM_NOT_REMOVE_CARD_WHEN_SUSPEND=y
    CONFIG_MMC_MSM_SDIO_SUPPORT=y
    CONFIG_MMC_MSM_CARD_HW_DETECTION=y
    CONFIG_MMC_MSM_SDC1_SUPPORT=y
    # CONFIG_MMC_MSM_SDC1_8_BIT_SUPPORT is not set
    # CONFIG_MMC_MSM_SDC1_DUMMY52_REQUIRED is not set
    CONFIG_MMC_MSM_SDC2_SUPPORT=y
    # CONFIG_MMC_MSM_SDC2_8_BIT_SUPPORT is not set
    CONFIG_MMC_MSM_SDC2_DUMMY52_REQUIRED=y
    CONFIG_MMC_MSM_SDC3_SUPPORT=y
    # CONFIG_MMC_MSM_SDC3_8_BIT_SUPPORT is not set
    # CONFIG_MMC_MSM_SDC3_DUMMY52_REQUIRED is not set
    # CONFIG_MMC_MSM_SDC4_SUPPORT is not set
    # CONFIG_MMC_MSM_SDC5_SUPPORT is not set
    # CONFIG_MMC_MSM_PROG_DONE_SCAN is not set
    # CONFIG_MEMSTICK is not set
    CONFIG_NEW_LEDS=y
    CONFIG_LEDS_CLASS=y
    # LED drivers
    # CONFIG_LEDS_PCA9532 is not set
    # CONFIG_LEDS_GPIO is not set
    # CONFIG_LEDS_LP3944 is not set
    CONFIG_LEDS_CPLD=y
    # CONFIG_LEDS_PCA955X is not set
    # CONFIG_LEDS_DAC124S085 is not set
    # CONFIG_LEDS_BD2802 is not set
    CONFIG_LEDS_MSM_PMIC=y
    # LED Triggers
    # CONFIG_LEDS_TRIGGERS is not set
    # CONFIG_HUAWEI_LEDS_BASE is not set
    # CONFIG_HUAWEI_INCIDENT_LED_NEW is not set
    CONFIG_SWITCH=y
    CONFIG_SWITCH_GPIO=y
    # CONFIG_ACCESSIBILITY is not set
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
    CONFIG_RTC_DEBUG=y
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    CONFIG_RTC_INTF_ALARM=y
    CONFIG_RTC_INTF_ALARM_DEV=y
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    # CONFIG_RTC_DRV_DS1307 is not set
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    # CONFIG_RTC_DRV_MAX6900 is not set
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    # CONFIG_RTC_DRV_PCF8563 is not set
    # CONFIG_RTC_DRV_PCF8583 is not set
    # CONFIG_RTC_DRV_M41T80 is not set
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8581 is not set
    # CONFIG_RTC_DRV_RX8025 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_DS3234 is not set
    # CONFIG_RTC_DRV_PCF2123 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_CMOS is not set
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # on-CPU RTC drivers
    CONFIG_RTC_DRV_MSM=y
    CONFIG_RTC_SECURE_TIME_SUPPORT=y
    # CONFIG_RTC_ASYNC_MODEM_SUPPORT is not set
    # CONFIG_RTC_DRV_MSM7X00A is not set
    # CONFIG_DMADEVICES is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_UIO is not set
    # TI VLYNQ
    CONFIG_STAGING=y
    # CONFIG_STAGING_EXCLUDE_BUILD is not set
    # CONFIG_USB_IP_COMMON is not set
    # CONFIG_PRISM2_USB is not set
    # CONFIG_ECHO is not set
    # CONFIG_COMEDI is not set
    # CONFIG_ASUS_OLED is not set
    # CONFIG_INPUT_MIMIO is not set
    # CONFIG_TRANZPORT is not set
    # Android
    CONFIG_ANDROID=y
    CONFIG_ANDROID_BINDER_IPC=y
    CONFIG_ANDROID_LOGGER=y
    CONFIG_ANDROID_RAM_CONSOLE=y
    CONFIG_ANDROID_RAM_CONSOLE_ENABLE_VERBOSE=y
    # CONFIG_ANDROID_RAM_CONSOLE_ERROR_CORRECTION is not set
    # CONFIG_ANDROID_RAM_CONSOLE_EARLY_INIT is not set
    CONFIG_ANDROID_TIMED_OUTPUT=y
    CONFIG_ANDROID_TIMED_GPIO=y
    CONFIG_ANDROID_LOW_MEMORY_KILLER=y
    CONFIG_MSM_RPCSERVERS=y
    # CONFIG_DST is not set
    # CONFIG_POHMELFS is not set
    # CONFIG_PLAN9AUTH is not set
    # CONFIG_LINE6_USB is not set
    # CONFIG_VT6656 is not set
    # CONFIG_FB_UDL is not set
    # RAR Register Driver
    # CONFIG_RAR_REGISTER is not set
    # CONFIG_IIO is not set
    # CONFIG_BSP_DEBUG is not set
    # File systems
    CONFIG_EXT2_FS=y
    CONFIG_EXT2_FS_XATTR=y
    # CONFIG_EXT2_FS_POSIX_ACL is not set
    # CONFIG_EXT2_FS_SECURITY is not set
    # CONFIG_EXT2_FS_XIP is not set
    # CONFIG_EXT3_FS is not set
    # CONFIG_EXT4_FS is not set
    CONFIG_FS_MBCACHE=y
    # CONFIG_REISERFS_FS is not set
    # CONFIG_JFS_FS is not set
    # CONFIG_FS_POSIX_ACL is not set
    # CONFIG_XFS_FS is not set
    # CONFIG_GFS2_FS is not set
    # CONFIG_OCFS2_FS is not set
    # CONFIG_BTRFS_FS is not set
    # CONFIG_NILFS2_FS is not set
    CONFIG_FILE_LOCKING=y
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY=y
    CONFIG_INOTIFY_USER=y
    # CONFIG_QUOTA is not set
    # CONFIG_AUTOFS_FS is not set
    # CONFIG_AUTOFS4_FS is not set
    # CONFIG_FUSE_FS is not set
    # Caches
    # CONFIG_FSCACHE is not set
    # CD-ROM/DVD Filesystems
    # CONFIG_ISO9660_FS is not set
    # CONFIG_UDF_FS is not set
    # DOS/FAT/NT Filesystems
    CONFIG_FAT_FS=y
    # CONFIG_MSDOS_FS is not set
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    # CONFIG_VFAT_FS_DUALNAMES is not set
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    # CONFIG_NTFS_FS is not set
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    # CONFIG_TMPFS_POSIX_ACL is not set
    # CONFIG_HUGETLB_PAGE is not set
    # CONFIG_CONFIGFS_FS is not set
    CONFIG_MISC_FILESYSTEMS=y
    # CONFIG_ADFS_FS is not set
    # CONFIG_AFFS_FS is not set
    # CONFIG_HFS_FS is not set
    # CONFIG_HFSPLUS_FS is not set
    # CONFIG_BEFS_FS is not set
    # CONFIG_BFS_FS is not set
    # CONFIG_EFS_FS is not set
    CONFIG_YAFFS_FS=y
    CONFIG_YAFFS_YAFFS1=y
    # CONFIG_YAFFS_9BYTE_TAGS is not set
    # CONFIG_YAFFS_DOES_ECC is not set
    CONFIG_YAFFS_YAFFS2=y
    CONFIG_YAFFS_AUTO_YAFFS2=y
    # CONFIG_YAFFS_DISABLE_LAZY_LOAD is not set
    # CONFIG_YAFFS_DISABLE_WIDE_TNODES is not set
    # CONFIG_YAFFS_ALWAYS_CHECK_CHUNK_ERASED is not set
    CONFIG_YAFFS_SHORT_NAMES_IN_RAM=y
    # CONFIG_YAFFS_EMPTY_LOST_AND_FOUND is not set
    # CONFIG_JFFS2_FS is not set
    # CONFIG_CRAMFS is not set
    # CONFIG_SQUASHFS is not set
    # CONFIG_VXFS_FS is not set
    # CONFIG_MINIX_FS is not set
    # CONFIG_OMFS_FS is not set
    # CONFIG_HPFS_FS is not set
    # CONFIG_QNX4FS_FS is not set
    # CONFIG_ROMFS_FS is not set
    # CONFIG_SYSV_FS is not set
    # CONFIG_UFS_FS is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V3=y
    # CONFIG_NFS_V3_ACL is not set
    # CONFIG_NFS_V4 is not set
    # CONFIG_NFSD is not set
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_COMMON=y
    CONFIG_SUNRPC=y
    # CONFIG_RPCSEC_GSS_KRB5 is not set
    # CONFIG_RPCSEC_GSS_SPKM3 is not set
    # CONFIG_SMB_FS is not set
    # CONFIG_CIFS is not set
    # CONFIG_NCP_FS is not set
    # CONFIG_CODA_FS is not set
    # CONFIG_AFS_FS is not set
    # Partition Types
    CONFIG_PARTITION_ADVANCED=y
    # CONFIG_ACORN_PARTITION is not set
    # CONFIG_OSF_PARTITION is not set
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_ATARI_PARTITION is not set
    # CONFIG_MAC_PARTITION is not set
    CONFIG_MSDOS_PARTITION=y
    # CONFIG_BSD_DISKLABEL is not set
    # CONFIG_MINIX_SUBPARTITION is not set
    # CONFIG_SOLARIS_X86_PARTITION is not set
    # CONFIG_UNIXWARE_DISKLABEL is not set
    # CONFIG_LDM_PARTITION is not set
    # CONFIG_SGI_PARTITION is not set
    # CONFIG_ULTRIX_PARTITION is not set
    # CONFIG_SUN_PARTITION is not set
    # CONFIG_KARMA_PARTITION is not set
    # CONFIG_EFI_PARTITION is not set
    # CONFIG_SYSV68_PARTITION is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    # CONFIG_NLS_CODEPAGE_737 is not set
    # CONFIG_NLS_CODEPAGE_775 is not set
    # CONFIG_NLS_CODEPAGE_850 is not set
    # CONFIG_NLS_CODEPAGE_852 is not set
    # CONFIG_NLS_CODEPAGE_855 is not set
    # CONFIG_NLS_CODEPAGE_857 is not set
    # CONFIG_NLS_CODEPAGE_860 is not set
    # CONFIG_NLS_CODEPAGE_861 is not set
    # CONFIG_NLS_CODEPAGE_862 is not set
    # CONFIG_NLS_CODEPAGE_863 is not set
    # CONFIG_NLS_CODEPAGE_864 is not set
    # CONFIG_NLS_CODEPAGE_865 is not set
    # CONFIG_NLS_CODEPAGE_866 is not set
    # CONFIG_NLS_CODEPAGE_869 is not set
    CONFIG_NLS_CODEPAGE_936=y
    # CONFIG_NLS_CODEPAGE_950 is not set
    # CONFIG_NLS_CODEPAGE_932 is not set
    # CONFIG_NLS_CODEPAGE_949 is not set
    # CONFIG_NLS_CODEPAGE_874 is not set
    # CONFIG_NLS_ISO8859_8 is not set
    # CONFIG_NLS_CODEPAGE_1250 is not set
    # CONFIG_NLS_CODEPAGE_1251 is not set
    CONFIG_NLS_ASCII=y
    CONFIG_NLS_ISO8859_1=y
    # CONFIG_NLS_ISO8859_2 is not set
    # CONFIG_NLS_ISO8859_3 is not set
    # CONFIG_NLS_ISO8859_4 is not set
    # CONFIG_NLS_ISO8859_5 is not set
    # CONFIG_NLS_ISO8859_6 is not set
    # CONFIG_NLS_ISO8859_7 is not set
    # CONFIG_NLS_ISO8859_9 is not set
    # CONFIG_NLS_ISO8859_13 is not set
    # CONFIG_NLS_ISO8859_14 is not set
    # CONFIG_NLS_ISO8859_15 is not set
    # CONFIG_NLS_KOI8_R is not set
    # CONFIG_NLS_KOI8_U is not set
    CONFIG_NLS_UTF8=y
    # CONFIG_DLM is not set
    # Kernel hacking
    CONFIG_PRINTK_TIME=y
    CONFIG_ENABLE_WARN_DEPRECATED=y
    CONFIG_ENABLE_MUST_CHECK=y
    CONFIG_FRAME_WARN=1024
    CONFIG_MAGIC_SYSRQ=y
    # CONFIG_STRIP_ASM_SYMS is not set
    # CONFIG_UNUSED_SYMBOLS is not set
    CONFIG_DEBUG_FS=y
    # CONFIG_HEADERS_CHECK is not set
    CONFIG_DEBUG_KERNEL=y
    # CONFIG_DEBUG_SHIRQ is not set
    # CONFIG_DETECT_SOFTLOCKUP is not set
    # CONFIG_DETECT_HUNG_TASK is not set
    # CONFIG_SCHED_DEBUG is not set
    # CONFIG_SCHEDSTATS is not set
    CONFIG_TIMER_STATS=y
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_DEBUG_SLAB is not set
    # CONFIG_DEBUG_KMEMLEAK is not set
    # CONFIG_DEBUG_PREEMPT is not set
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_RT_MUTEX_TESTER is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    # CONFIG_DEBUG_MUTEXES is not set
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_SPINLOCK_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    CONFIG_STACKTRACE=y
    # CONFIG_DEBUG_KOBJECT is not set
    CONFIG_DEBUG_BUGVERBOSE=y
    CONFIG_DEBUG_INFO=y
    # CONFIG_DEBUG_VM is not set
    # CONFIG_DEBUG_WRITECOUNT is not set
    # CONFIG_DEBUG_MEMORY_INIT is not set
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    # CONFIG_DEBUG_CREDENTIALS is not set
    # CONFIG_BOOT_PRINTK_DELAY is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    # CONFIG_RCU_CPU_STALL_DETECTOR is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
    # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
    # CONFIG_FAULT_INJECTION is not set
    # CONFIG_LATENCYTOP is not set
    # CONFIG_SYSCTL_SYSCALL_CHECK is not set
    # CONFIG_PAGE_POISONING is not set
    CONFIG_NOP_TRACER=y
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_RING_BUFFER=y
    CONFIG_EVENT_TRACING=y
    CONFIG_CONTEXT_SWITCH_TRACER=y
    CONFIG_RING_BUFFER_ALLOW_SWAP=y
    CONFIG_TRACING=y
    CONFIG_TRACING_SUPPORT=y
    CONFIG_FTRACE=y
    # CONFIG_FUNCTION_TRACER is not set
    # CONFIG_IRQSOFF_TRACER is not set
    # CONFIG_PREEMPT_TRACER is not set
    # CONFIG_SCHED_TRACER is not set
    # CONFIG_ENABLE_DEFAULT_TRACERS is not set
    # CONFIG_BOOT_TRACER is not set
    CONFIG_BRANCH_PROFILE_NONE=y
    # CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
    # CONFIG_PROFILE_ALL_BRANCHES is not set
    # CONFIG_STACK_TRACER is not set
    # CONFIG_KMEMTRACE is not set
    # CONFIG_WORKQUEUE_TRACER is not set
    # CONFIG_BLK_DEV_IO_TRACE is not set
    # CONFIG_RING_BUFFER_BENCHMARK is not set
    # CONFIG_DYNAMIC_DEBUG is not set
    # CONFIG_SAMPLES is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    CONFIG_ARM_UNWIND=y
    CONFIG_DEBUG_USER=y
    CONFIG_DEBUG_ERRORS=y
    # CONFIG_DEBUG_STACK_USAGE is not set
    # Security options
    # CONFIG_KEYS is not set
    # CONFIG_SECURITY is not set
    # CONFIG_SECURITYFS is not set
    # CONFIG_SECURITY_FILE_CAPABILITIES is not set
    CONFIG_CRYPTO=y
    # Crypto core or helper
    # CONFIG_CRYPTO_FIPS is not set
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    CONFIG_CRYPTO_AEAD=y
    CONFIG_CRYPTO_AEAD2=y
    CONFIG_CRYPTO_BLKCIPHER=y
    CONFIG_CRYPTO_BLKCIPHER2=y
    CONFIG_CRYPTO_HASH=y
    CONFIG_CRYPTO_HASH2=y
    CONFIG_CRYPTO_RNG=m
    CONFIG_CRYPTO_RNG2=y
    CONFIG_CRYPTO_PCOMP=y
    CONFIG_CRYPTO_MANAGER=y
    CONFIG_CRYPTO_MANAGER2=y
    # CONFIG_CRYPTO_GF128MUL is not set
    # CONFIG_CRYPTO_NULL is not set
    CONFIG_CRYPTO_WORKQUEUE=y
    # CONFIG_CRYPTO_CRYPTD is not set
    CONFIG_CRYPTO_AUTHENC=y
    # CONFIG_CRYPTO_TEST is not set
    # Authenticated Encryption with Associated Data
    # CONFIG_CRYPTO_CCM is not set
    # CONFIG_CRYPTO_GCM is not set
    # CONFIG_CRYPTO_SEQIV is not set
    # Block modes
    CONFIG_CRYPTO_CBC=y
    # CONFIG_CRYPTO_CTR is not set
    # CONFIG_CRYPTO_CTS is not set
    CONFIG_CRYPTO_ECB=y
    # CONFIG_CRYPTO_LRW is not set
    # CONFIG_CRYPTO_PCBC is not set
    # CONFIG_CRYPTO_XTS is not set
    # Hash modes
    CONFIG_CRYPTO_HMAC=y
    # CONFIG_CRYPTO_XCBC is not set
    # CONFIG_CRYPTO_VMAC is not set
    # Digest
    CONFIG_CRYPTO_CRC32C=y
    # CONFIG_CRYPTO_GHASH is not set
    # CONFIG_CRYPTO_MD4 is not set
    CONFIG_CRYPTO_MD5=y
    # CONFIG_CRYPTO_MICHAEL_MIC is not set
    # CONFIG_CRYPTO_RMD128 is not set
    # CONFIG_CRYPTO_RMD160 is not set
    # CONFIG_CRYPTO_RMD256 is not set
    # CONFIG_CRYPTO_RMD320 is not set
    CONFIG_CRYPTO_SHA1=y
    # CONFIG_CRYPTO_SHA256 is not set
    # CONFIG_CRYPTO_SHA512 is not set
    # CONFIG_CRYPTO_TGR192 is not set
    # CONFIG_CRYPTO_WP512 is not set
    # Ciphers
    CONFIG_CRYPTO_AES=m
    # CONFIG_CRYPTO_ANUBIS is not set
    CONFIG_CRYPTO_ARC4=y
    # CONFIG_CRYPTO_BLOWFISH is not set
    # CONFIG_CRYPTO_CAMELLIA is not set
    # CONFIG_CRYPTO_CAST5 is not set
    # CONFIG_CRYPTO_CAST6 is not set
    CONFIG_CRYPTO_DES=y
    # CONFIG_CRYPTO_FCRYPT is not set
    # CONFIG_CRYPTO_KHAZAD is not set
    # CONFIG_CRYPTO_SALSA20 is not set
    # CONFIG_CRYPTO_SEED is not set
    # CONFIG_CRYPTO_SERPENT is not set
    # CONFIG_CRYPTO_TEA is not set
    CONFIG_CRYPTO_TWOFISH=y
    CONFIG_CRYPTO_TWOFISH_COMMON=y
    # Compression
    CONFIG_CRYPTO_DEFLATE=y
    # CONFIG_CRYPTO_ZLIB is not set
    # CONFIG_CRYPTO_LZO is not set
    # Random Number Generation
    CONFIG_CRYPTO_ANSI_CPRNG=m
    CONFIG_CRYPTO_HW=y
    CONFIG_BINARY_PRINTF=y
    # Library routines
    CONFIG_BITREVERSE=y
    CONFIG_GENERIC_FIND_LAST_BIT=y
    CONFIG_CRC_CCITT=y
    CONFIG_CRC16=y
    # CONFIG_CRC_T10DIF is not set
    # CONFIG_CRC_ITU_T is not set
    CONFIG_CRC32=y
    # CONFIG_CRC7 is not set
    CONFIG_LIBCRC32C=y
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_GENERIC_ALLOCATOR=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_IOPORT=y
    CONFIG_HAS_DMA=y
    CONFIG_NLATTR=y
  7. ere95588
  8. PerGert
    PerGert Member
    Huawei IDEOS S7 Slim
    Did you know how to use attachments system or Pastebin.com - #1 paste tool since 2002! ?
    Maaaan, this is AWESOME piece of work!
    But from the beginning. If your S7 Slim came from Hungarian distribution it's probably identical to those from all over the world - the id for this model is 201u. I live in Poland and i've been using official Hungarian Froyo without problems :)
    After start the Hungarian language make me a little bit disorientated but with your tutorial i managed to change it ;)
    Ok, to the testing!
    1. System works really fast. Sometimes i can feel a little slowdowns but probably its a problem dalvik heap size (i did not remember what are your settings from build.prop - i'll try to look at it later)
    2. Bluetooth and Camera did not work as you say.
    3. Have you managed to change density in build.prop? You have commented lines about density but after i put them back a tablet seems to stopping at boot :/ It will be really cool if we can get an tablet ui...
    4. I have some problems with lockscreen. After the first boot everything was good but after i changing a lockscreen options in CyanogenMod settings the lockscreen have some issues with himself. It seeems like changing options "pushed" lockscreen to the right (in landscape mode) so if i want to unlock i have to slide circle near the menu button because unlock icon is off-screen. Probably a factory reset would help but maybe you'll find a fix.
    5. I can't change any shotcuts in a notification drawer. It seems like cyanogenmod settings are not saved.
    6. I've also get some reboots after using a notification drawer shortcuts. Maybe you should get rid of them at all if you can?
    7. The system is draining battery like crazy with default settings. Default cpu have a ondemand scaling from 245 to 998Mhz but Android keeps cpu at 998Mhz nearly all the time. Changed to "conservative" scaling and it keeps cpu at 245Mhz which is better for power-saving. Also: after unlocking screen the cpu is sometimes stalled at highest possible setting.
    8. In Poland we have a "Aero 2" free internet service (check T for details) but a sim card from them have a blocked TS11 service which means no telephony at all and tablet is not showing a gsm signal power - not every rom can work without it but your works great. Big thanks for this!
    9. The button leds are not working.
    10. Wifi indicator on the status bar only shows a connection status ("connected" or "trying to connect") but icon in settings works good and shows real signal power.
    Anyway this rom is really great and i want to thank you for your work :D
  9. asturel
    asturel Senior Member
    Hungary
    what's that tablet ui?
    i know about the notification widget bug, but i didnt not changed anything on it. I did not expirienced battery drain bug (but if i check the speed in developer options its rly ups into 1ghz)
    i have configured the button led to power up only in dark. but i can change in display/automatic backlight -> use custom levels
    dropbox blocked my public folder due to high traffic, new roms avaialble at Index of /cm9_s7/ fixed few things. (added a new kernel with few new cpu governors)
    p.s.: did not have time to compile the kernel for s7 fat,
    • Like Like x 2
  10. Jota
    Jota Member
    BH, Brazil
    Ideos S7_105
    As far I remember in the S7 the same Broadcom chip manages both the wi-fi and bluetooth, so there should be some way to make bluetooth work.
    PS:
    sorry for that long post, was in a hurry and didn't remember about pastebin. :( Hope it helps you to compile a good kernel for the s7_10x!
  11. beenhow
    beenhow Junior Member
    China
    Huawei S7 slim
    thanks for your hard work! hope you can modifiy it.
  12. PerGert
    PerGert Member
    It's a ICS UI prepared especially for tablets. It's activated automatically on devices with DPI >= 120 You can see a short comparison here:
    Hmm, i'll try to test it without a sim card - maybe thats the source of the problem with my tablet.
    Thanks, I'll try the new version tomorrow :)
  13. beenhow
    China
    Huawei S7 slim
    I tried, i failed on my s7 slim 201u, it seems that this rom is for s7, not slim.
  14. ere95588
    ere95588 Senior Member
    Can introduce your development environment configuration and github address? Detailed steps I want go to download and compile their own s7 the rom, try.s7 development environment configuration introduces very little.
  15. asturel
    Hungary
    https://github.com/asturel/
    • Like Like x 6
asturel s7 slim decrypt password storage
custom rom huawei ideos s7 slim
custom rom huawei s7 slim
custom rom ideos s7 slim
huawei ideos s7 slim cyanogenmod
huawei ideos s7 slim rom
huawei s7 slim rom
ideos s7 slim custom rom
ideos s7 slim rom
