Rooting Help
Discussion in 'Acer Iconia Tab A500 Forum' started by frogboy, Aug 20, 2011.
  1. frogboy
    frogboy Member
    NY
    Acer A500
    I've tried repeatedly to root my new A500, and the GingerBreak just keeps spinning. I have followed the Androidfc directions to the best of my ability. Any help out there?
  2. wiro67
    wiro67 Member
    netherlands
    a500
    well this is the procedure i followed with gingerbreak
    below is the walkthrough of how to root this device
    1. make sure usb debugging is turned on and unknown sources is selected
    2. have a micro sd card inserted and turn the tablet on portrait and lock it with the switch to fix it in portrait
    3. download and execute the attached apk. (i had to download from my comp and transfer to the tablet for it to work)
    4. once the apk is installed run the root procedure within the app which was installed
    5. wait and you will receive full root access
    did you lock it in portrait mode switch next to volume button ?
  3. ClayB
    ClayB Member
  4. HD87
    HD87 Senior Member
    US
    Acer Iconia A500 tab
  5. alphawave7
    alphawave7 Member
    San Fran
    Nook Color
    Probably the easiest Android root procedure in existence! :D
  6. testshoot
    testshoot Member
    Minnesnowta
    A500
    Is it safe to do the 3.1 to 3.2 upgrade AFTER rooting? I was holding off on the 3.2 upgrade until I got rooted.
  7. HD87
    HD87 Senior Member
    US
    If you have 3.1 rooted, I recommend you flash to a 3.2 ROM, with superuser preinstalled, check out this ROM ->http://www.androidtablets.net/forum...6738-thor-a500-rom-v14-2-android-3-2-1-a.html
    • Like Like x 2
gingerbreak spinning
