Tablet newbie needs help (usb drivers)
Discussion in 'ViewPad 10' started by metal2.3, Nov 6, 2011.
  1. metal2.3
    metal2.3 Member
    Argentina
    viewpad 10s
    Hey:
    i have a viewpad 10s and i`ve downloaded the usb drivers but i cannot install them. Theres no .exe to start installing , what i`m missing?? . I plug the usb cable to my pc and tablet (do the start sequence that the manual shows) but nothing... no soft nor hard recognition whatsoever. I`ve used the search but i could not find this problem posted...
    Thanks in advance!
    edit: my pc is running with win 7 ultimate
  2. metal2.3
    metal2.3 Member
    Argentina
    viewpad 10s
    238 views and 0 replies?? thanks a lot for reading....problem solved. Close.
  3. mmp669
    mmp669 Member
    Maybe people don't know how to fix this. Why didn't you post your solution and it maybe helpful for some people? That's how a community should work.
  4. metal2.3
    metal2.3 Member
    Argentina
    viewpad 10s
    I did not post my solution because nobody seem to care about my question....
    Anyway , i`ve solved the problem by installing windows xp and trying again , simple and quick.
  5. amarillo
    amarillo Member
    Well hello metal2.3, i've tried to follow your steps but nothing happend. I have to notebooks one with Xp and the other with vista home. I've tried to connect via the male usb my viewpad 10s android but i didn't manage to get into the recovery mode. I would be thankfull if you could analyze me your method. Thanks in advance.
  6. metal2.3
    metal2.3 Member
    Argentina
    viewpad 10s
    Amarillo:
    first yo need to set up a folder with the usb drivers (desktop for quick access) then , just follow this simple directions ( http://www.vujke.com/download/E-ViewPad 10s Firmware Update SOP.pdf ) , the most difficult thing for me was to do the buttons sequence (don`t know why!!) to get to recovery mode. If you did install the usb drivers uninstall them and do the process with a fresh start. Good luck!
m57te driver download
tablet driver sop
