Udisk + Screen problem
ah2003t
Hi every one
I have problem with My device when I try to upgrade it first problem I can't install HoneyCombo version because My device have not Udisk. And when I try to install anther version it well install ok but the screen is not ok because it divided to 2 screen.
Can any one HELP my.
thank you.....
Clintzodiac
7
Hi what size screen have you got? if the screen is repeated down the bottom then you have an 8" screen and you need to look at firmware for an 8" screen this is mostly 7" screens here.
Clintzodiac
7
Without seeing a picture of the terminals and layout, I would check out Eken M003 as it has the same processor and is 8" look for firmware by Ecotox it has served me well.
ah2003t
i don't know exactly which screen I have but I know the Model number may be you known about it. model WinPad B08.
Thank You
