WIFI Issue with Android 2.2 epad 7" WMT2.1.2
Discussion in 'Gome Flytouch Problems' started by venomancer1980, Jan 4, 2011.
  1. venomancer1980
    venomancer1980 Member
    philippines
    epad 7" 2.2
    Hello to all I am a newbie and I hope someone can help. I bought a brandnew MID/epad 7" that comes with Android 2.2 and WMT2.1.2 installed. I tested the wifi capabilities and found that it does not connect to almost all wifi hotspots I tried it on. There was one time that it successfully connected and I was able to browse for about 5 minutes and then it got disconnected and never connected again to the same hotspot it connected to :confused:. All the available hotspots are detected and has strong signal, however I am unsuccessful to connect my device to any. It just say that its obtaining ip address.....then Disconnect.. Or obtaining ip address...then unsuccessful :(. I googled my issue and found that this is an issue to many epad 7" with the same android os and build that I have. Would a firmware upgrade solve this issue? Also I would like to ask members here with the Android 1.6 installed, if they experience the same issue? Thanks in advance.
  2. nikolas22t
    nikolas22t Member
    Cyprus
    Epad 7" - Epad 10"
    I have the same problem with my 7" tablet android pc , did you fix the problem ? you did a firmware upgrade ? Please advice.
    I have the same device in 10" and its working fine!
  3. r2d2r2d2
    r2d2r2d2 Member
    Hello to all,
    I'm new in the android wold and i'm a bit lost.
    I just received my apad/epad ... or whatever it is and there is no way to connect via wifi. It tries to connect and says there is no wifi connections (no true).
    I've tried with WefiConnect & WifiManager but, no way.
    model: generic
    memory size: 256mb
    firmare:android 3.0
    kernel: 2.6.29-00236-g4f8dbbb-dirty
    comp: WMT2.1.2
    BlueLED and green headphone
    Hope someone can help.
    Thank you
  4. tujuhkalitujuh
    tujuhkalitujuh Member
    MID 7
    I also had the same problem with all 5 android tab green led vibrating on start.
    Connected but after some minutes/seconds it becomes unable to access data, even the wifi status still connected.
  5. macedpo
    macedpo Member
    Have the very same Wifi problem. Bought a new 7" tablet a few day's ago.
    Did anyone found a solution ?
  6. uplade3
    uplade3 Super Moderator Staff Member
    Asheville N.C.
    Flytouch II/SuperPAD Droid Charge/Razr, Galaxy S4
    First, Try a factory reset.
    Second, Try to flash the firmware to something higher.
    Third, Reset again.
    You may have an operational wifi tablet after all of that.
  7. macedpo
    macedpo Member
    Done all that... have flashed 2 different firmwares... problem is still there.
    The tablet sees my wifi-router and connects, gets IP-address and... disconnects. Or even at less then 1 meter from router tablet says... out of range.
  8. uplade3
    Asheville N.C.
    Ok then we have narrowed it down to a hardware problem. The best bet would be to return it and get a better tablet.
    Unless you feel like opening it and replacing the NIC
  9. oofy
    oofy Member
    I have a 10" and am having wifi issues...it was working great, did a reset because I'm selling it and wanted my info deleted and now the wifi won't connect. It tries to obtain ip but fails...please help???
  10. Kontra152
    Kontra152 Member
    kontra152@msn.com
    Android 2.2 mid 7" tablet
    Same problem I just got my tablet it's the 7 inch one I purchased it for my wife and she was like hey I can't get on the Internet so I have to use the Ethernet connection until I can sought it out if any of you can get the problem fixed I sure would appreciate the reply to my reply also I see one person said flash the Firmware could you please let me know how to do it I'm afraid if I reset this this it may not work all together thanks and I hope y'all get your problems worked out.
e-pad wifi
epad android wifi problem
epad internet setting
epad tab wifi setting tips
How to enabke wifi on an epad tablet
tablet epad non wifi
why did in epad tab is not oning wifi
wifi settings for android epad tablet
wifi working on phone but not in epad
wmt5176
