Wireless Tether for Kyros MID7015a
Discussion in 'Coby Tablet Accessories' started by uslacson1, Mar 21, 2011.
  1. uslacson1
    uslacson1 Member
    Nutley
    Kyros MID7015
  2. uslacson1
    uslacson1 Member
    Nutley
    Kyros MID7015
  3. Cutty1
    Cutty1 Member
    Canada
    7" mid Tablet (Dreambook)
    I can't Seem to Find Softap For Samsung....
    Can you explain a little more What Setting Have to Take Place Please ...Thanx
    Oops I forgot to Mention I'm Using A Huawei U8100
    The Kyros Can't Find It..
  4. uslacson1
    uslacson1 Member
    Nutley
    Kyros MID7015
    Go to settings on change device profile set to auto or your specific device (Phone), on change set up method options I tried what was listed and softap works for kyros.
  5. Cutty1
    Cutty1 Member
    Canada
    i'm Guessing You have a Samsung Phone....
    My phone Doesn't Show up in the List ..
    I also put Auto as My Device But When I do that softap Isn't there anymore...
    Maybe i need to change the WPA_Suplicant file.
  6. uslacson1
    uslacson1 Member
    Nutley
    Kyros MID7015
    What phone are you installing it on?
  7. Cutty1
    Cutty1 Member
    Canada
    Huawei U8100
  8. Delaney64
    Delaney64 Member
    Coby Kryos MID 7015
    I am running watery kyros at the moment. My D1 doesnt have softap option either. I also used the Gscript trick with the wifi files (found of xda developers) to gain access to adhoc and switch back to normal features (which i thought you had to do but I guess 7015a is different?). Is there a way to reverse the process?
  9. uslacson1
    uslacson1 Member
    Nutley
    Kyros MID7015
    Try generic on device -profile then WEXT (ad-hoc) on set up method.
  10. Delaney64
    Delaney64 Member
    Coby Kryos MID 7015
    My tablet was not even able to pick up that signal.
  11. Cutty1
    Cutty1 Member
    Canada
    I Having just about the Same luck..
  12. uslacson1
    uslacson1 Member
    Nutley
    Kyros MID7015
  13. Cutty1
    Cutty1 Member
    Canada
    It's no biggie for me. I just thought it would nice to have wifi everywhere I go.
    Actually I think I know the Problem.....i was reading the link you Gave me and It was saying that I needed a Custom Kernal . I'm still using the Stock one....
  14. Delaney64
    Delaney64 Member
    Coby Kryos MID 7015
    I think the tutorial and files from xda isnt compatible with the kyros 7015a update/ waterykyros. I attempted to reinstall the adhoc files and used gscript and I had to reinstall waterykyros.
