sicksquirrel
- Jan 26, 2011
- 24
- 0
How do I remove a microSD card? I don't see a button/hole to do so and can't locate my instruction manual.
Why would you think that? But it worked, thank you.It doesn't sound like you actually have one in it, but if you do, just press down on it with your nail and it will pop up.
Thanks, I need to know that also. Now for my question on the Coby 7015 I bought this from a friend who said it had been rooted. I went in to change my font to a smaller size and it will not stay there. It always goes back to the large size. Any thoughts on how to correct this. I went into setup to do this.
It has 2.1 on it which is the same software as my cell phone.
There is no way. It's a limitation/bug in the firmware I believe. It won't save the setting.
