Power On -> Unlock -> Then Black Desktop - Can't use anything. Help.
Hypoglybetic
I own a FlyTouch 2 or 3 with 512 RAM. I tore the damn thing apart to verify that it does indeed have 4 128 MB DDRII Samsung chips inside with an x220 processor.
Anyways, so I rooted this baby and didn't do anything else to it. I was using it one night and decided to let it fully die. The next morning I plugged it in and turned it on. After booting, I slid my stylus over the screen to unlock the tablet. As soon as I unlocked the screen the desktop disappeared. "Home" program did not run/open. Nothing will open or run.
Recovery mode did not work (although it reset my background).
I can open the device and remove the 4GB microSD card that contains the data.
What is the easiest way to re-install android on this or fix my issue since I have access to the internal storage.
Thanks.
You need to flash the rom. You could either use a custom build or the most recent official build.
Sent from my SuperPAD using Android Tablet Forum
