Process Problems
strahls
Hi all
I hope someone can help me out
I have a Super Pad 111 and I cant get into anything, I keep getting "The process android.process.acore has stopped unexpectedly.Please try again". Well try again I have with no luck.
Went to the User's Manual and thought I would re-set the Defaults but cant even do that.
Instrustructions say press Menu> System Settings> Privacy> Defaults....... when I press Menue, Settings is displayed but not System Settings and when I go into Settings there is no Privacy settings only WiFi and Wireless settings, getting frustrated, please help me out someone
Regards Andrew
Hi Andrew, congratulations on your new tablet and welcome to Android Tablets. Glad you decided to join the forum, but sorry to hear you're having problems with the tablet. I'm going to move your thread over to the Gome Flytouch II Variant 2 section for you. The folks there are the most knowledgeable about your tablet and hopefully will be able to help you out. Good luck!
