Ainol NOVO II Advanced Ice Cream 4 came with no google market place or flash palyer
brettr101
I purchase these for resell no google market place is installed supplier claims it runs Flash 11 but it will not. I need to find out how to install flash 10.1 and market place apk files any hhelp out there? I know how to hook tablet up via USB mass storage it seems to have installed flash 10.1 but the market place apk will not.
Thanks,Brett
petesimon
I ordered this tablet -after- I discovered the problem via forums that you're writing about. I am still waiting for the thing in the mail.
I think some gurus on the web have come up with some solutions. How (what methods or steps) did you try to install Flash and Android market? I'm also going to need to do this to my tablet when it arrived in the mail. I think you need some fresh apk files for android market (google play market) to work...such as GoogleServicesFramework.apk and Vendor.apk and MarketUpdater.apk and maybe others but I could be wrong or incomplete. and get a copy of adb.exe with AdbWinApi.dll and AdbWinUsbApi.dll so you can do adb commands in a windows command prompt which will let you manipulate app and files inside most android devices when "USB Debugging" is enabled.. Hey filestube.com is a good search engine for files. ADB should be documented online android.com or similar site. You can also try this forums links:
Newbies Guide to Novo 7 Advanced II - SlateDroid.com
[Scripts] - Ainol Novo7 Advanced-II ICS 4.0.3 Market/Gapps Script - SlateDroid.com
http://www.androidtablets.net/forum/novo7/34289-home-ainol-novo7-advancedii.html
Also, you might try other app stores like SlideMe.org http://slideme.org and Amazon's http://amzn.to/wk6dK2
and I tried GetJar http://getjar.com but it didn't work for me on my little phone.
I'll get back to this later...after I get the tablet in my hands.
