Coby 7060 flash with 7065 problem vampirefo need help
alland
19
Hi I'm new to this forum. I'm stuck with MTP. I've use the root stock 7065 rom vampirefo upload. also, is there a way to read and write on the internal SDCARD and phone storage because it's read only and lastly i cannot find the .android on my phone because I would like to edit adb_usb.ini so i can put driver on my pc.
hope you guys can help.
thanks a bunch
alland
19
anyone knows how to fix this? can i request a stock rom for 7065 and 7060?
kheemt
14
i had the same problem with this 7065 stock rom too, my tablet now has 1 gb of internal memory i hope vapirefo can help us
tpaine
525
130
is this for me?
do i have to flash via cwm the adb? i didnt do that is that the reason why i lost the storage?
If you don't have adb setup, you can use the same command from a terminal window on your tablet. Here's my 7042 output:
root@android:/ # busybox df -h
busybox df -h
Filesystem Size Used Available Use% Mounted on
tmpfs 407.1M 60.0K 407.1M 0% /dev
tmpfs 407.1M 0 407.1M 0% /mnt/asec
tmpfs 407.1M 0 407.1M 0% /mnt/obb
/dev/block/nandd 393.7M 206.1M 187.6M 52% /system
/dev/block/nande 1.5G 550.6M 961.2M 36% /data
/dev/block/nandh 503.9M 8.4M 495.5M 2% /cache
/dev/block/vold/93:64
1.2G 326.7M 936.8M 26% /mnt/sdcard
1.2G 326.7M 936.8M 26% /mnt/secure/asec
root@android:/ # df -h
df -h
Filesystem Size Used Free Blksize
-h: No such file or directory
1|root@android:/ #
The change you made copies the files to the system directory. the system directory is ~300mb.
It does nothing to change the system partition, or any partition size, so you have lost nothing but a small amout of space in the system partition.
kheemt
14
busybox df -h
df -h
1|root@android:/ #
Thanks for the reply tpaine, unfortunately im very new to this android thing, although ive rooted my sony arc s and my alcatel onetouch idol ultra im still a newbie,
this is my output,
app_62@android:/ $ # busybox df -h
app_62@android:/ $ busybox -h
-h: applet not found
1|app_62@android:/ $ busybox df -h
tmpfs 427.1M 80.0K 427.0M 0% /dev
tmpfs 427.1M 0 427.1M 0% /mnt/asec
tmpfs 427.1M 0 427.1M 0% /mnt/obb
ubi0_0 438.5M 222.9M 210.9M 51% /system
/dev/block/mtdblock6 127.8M 18.2M 109.6M 14% /factory
ubi1_0 1.5G 455.3M 1.0G 30% /data
/dev/block/mtdblock7 511.0M 18.5M 492.5M 4% /cache
/dev/block/vold/250:37
994.3M 481.7M 512.5M 48% /mnt/sdcard
df: /mnt/secure/asec: Permission denied
/dev/block/vold/253:1
14.8G 1.1G 13.8G 7% /mnt/sdcard/external_sdcard
/dev/block/dm-0 22.3M 20.3M 2.0M 91% /mnt/asec/com.gamecircus.PrizeClaw-1
/dev/block/dm-1 42.6M 41.0M 1.6M 96% /mnt/asec/ru.mail.games.android.JungleHeat-1
/dev/block/dm-2 18.3M 16.9M 1.3M 93% /mnt/asec/com.leftover.CoinDozer-1
/dev/block/dm-3 61.8M 59.3M 2.6M 96% /mnt/asec/com.disney.wheresmywater2_goo-1
can you help me understand what this means thanks in advance
tpaine
525
130
As you can see, the partitions are similar in size between the 2 tablets. On my 7042, I have dozens of apps loaded. The limited storage makes one more efficient.
With the 7065 software, you have playstore and working google apps. Adding gapps in the 7042 worked for the most part, but certain features didn't work. I'd say youv'e done a good thing for your tablet.
tpaine
525
130
I have no ideal what you are talking about.
kheemt stated in another post that he thoght his 7060 had 16gb of storage before the change to the 7065 software. Now he says, he only has 1gb. I tried to explain that the software change has nothing to do with the tablet partitions.
vampirefo.
Developer
Nov 8, 2011
3,836
1,394
kheemt has only made three posts, none state he had 16 GB nor do any state he flashed the 7065 rom, he is on stock 7060 rom, as he systems size clearly shows, had he installed 7065 his system would be using almost 300 MB instead of stock less than 225 MB.
vampirefo.
Developer
Nov 8, 2011
3,836
1,394
He made several posts overnite that disappeared. Maybe mods.
OK, I didn't see them, anyway his used system is too small to be 7065. You can look at your own system used on your 8065, will be about the same as 7065, 7060, 1060, are much smaller as they don't have gapps installed.
Traveller
2,858
983
Maybe i'm confused about the member, but he made several threads overnite that disappeared. Maybe mods.
Dunno how that happened. He had made duplicate posts which I merged, but I must have deleted the merged posts as well without realizing it. I've restored his post. In it he claims to have flashed his 7060 with 7065 firmware, but assuming vampirefo is right, then he must have done something wrong along the way.
