Flashed My ZT180, now no sound
Discussion in 'Zenithink ZT180 10 Generation 2' started by bwharton, Oct 18, 2011.
  1. bwharton
    bwharton Member
    7" epad & 10" Zenithink 180t 2nd Generation
    Ok so I flashed my
    ZT180 G0 10in v2 ( I think)
    Android version 2.2
    Kernal 2.6.32.9
    now i have no sound, can anyone help?
    I dont even know where to start to fix the problem
    PLease someone help. Cant watch a video, play angry birds etc... My electronic babysitter is failing!
    Please help
  2. Cooled68
    Cooled68 Member
    MO.
    ZT-180 2nd gen 512MB
    I too have a Zenithink ZT180-F 10 Generation 2 512 MB, but i installed the wrong firmware epad_256M_nand_android_2.2_0120_Public. But since then I have installed the correct one which is android_2.2_512_4GB_10_0613 with F. It seems like even though the Gen1 software kills the audio on the Gen2 Pad. The tablet runs really well just no sound. I wish i had a solution for this nightmare.
  3. Cooled68
    Cooled68 Member
    MO.
    Wish i had the default factory software, maybe it would install the sound drivers back correctly.
  4. Cooled68
    Cooled68 Member
    MO.
    • Like Like x 2
  5. dwh6249
    dwh6249 Member
    New York
    zt-180-102 V2
    Cooled68
    [​IMG] I am new to this and was wondering if you could tell me what I was suppose to do with the unzipped files that you recommended above.
    I did the same thing with my zt-180 and now have no sound. I am new to tablets and so should I put this on my tf card and then reboot like when I flashed it?
    Not sure what to do here. Thanks for any help!!!
  6. blaw918
    blaw918 Member
    florida
    zt180v2
    i see u went with smaxtors custom rom. they work very nice but u must have flashed the wrong rom for ur tablet. flash a different one of his roms. u have to make sure u get the right rom for ur specific model #. i used his roms and tablet worked much better than stock till i fried the power port by plugging in wrong charger
audio problem epad zt180
audio zt180
how to install smaxtors custom zt180v2
zenithink sound problem
