From mcl rom 201 for 4.1.1 to mcl rom 103 for 4.0.4
Discussion in 'Lenovo IdeaTab A2109 Technical' started by a2109a, Jan 15, 2013.
  1. a2109a
    a2109a Member
    Lenovo IdeaTab A2109A
    I want to go back from mcl rom 201 (4.1.1) to mcl rom 103 (4.0.4).
    How are the steps? The tablet is already rooted.
    Do I need to install a2109_cwmrecovery-6.0.1.9c.img ? I had installed a2109_cwmrecovery-6.0.1.9d.img for 4.1.1 already.
  2. FloRider
    FloRider Senior Member
    Florida
    Lenovo A2109
    First you install the ROM, then you flash the cwm version for that ROM. I think it's simply:
    1. Wipe data / factory reset
    2. Install MCL 103.
    3. Flash the 'c' version of cwm.
  3. a2109a
    a2109a Member
    Are you sure it is not the other way round, first cwm and then mcl?
    How do I wipe the data? Do I have to use Volume+ / Power on to get to the wipe menu? See screenshots, there are a lot of errors. Can I ignore them? After I have done the wipe and do a reboot, I see my old system with all the installed apps.
  4. FloRider
    Florida
    Lenovo A2109
    Hmm... I hate to say this, but first flash the .9d cwm just to be sure. Then, enter recovery -- yes, use power + vol up. Then format the devlog (I think that's the name). Then do a factory reset. After that, install 4.0.4. Then go back to fastboot to flash the .9c cwm. Formatting the devlog should get rid of some of those errors, but others look more serious. This is my best suggestion at this point, and it should be a relatively quick process.
  5. a2109a
    a2109a Member
  6. mcl630
    mcl630 Senior Member
    Illinois, USA
    Lenovo IdeaTab A2109A, Archos A101IT
    Add step 2a) Install the ICS bootloader.
  7. FloRider
    Florida
    Lenovo A2109
    Oops. I'm sure it's in a post, but how do you change the bootloader?
  8. a2109a
    a2109a Member
  9. Ravak
    Ravak Member
    UK
    IdeaTab A2109
    Either:
    1. Reboot to Clockwork "d", install ICS Bootloader (once you reboot, Clockwork will no longer work, and neither will your JB ROM)
    2. Reboot to Fastboot, install Clockwork "c" (now Clockwork will be working)
    3. Reboot to Clockwork "c", install ICS ROM
    Or:
    1. Reboot to Clockwork "d", install ICS ROM and ICS Bootloader (once you reboot, Clockwork will no longer work)
  10. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    I run the JB cw_recovery on both ICS and JB bootloaders without issue. So there may not be a need for the ICS cw recovery any more.
  11. a2109a
    a2109a Member
    Where do I get ICS bootloader? Is this a file?
    Edit: I found:
    A2109A_ICSBootloader.zip
    MD5: 15b243e9e2bad8236bbaf06c05a17351
    Is this the right one?
  12. a2109a
    a2109a Member
    Edit:
    ATTENTION: A while afterwards USB-debugging / development options could not be activated anymore, which is very critical, since you need it to flash the device.
    I could flash from MCL ICS to stock ICS by pressing VolumUp + Power (still no usb-debugging)
    Factory reset of ICS from the options menu (still no usb-debugging)
    And then I tried a few times to upgrade to Stock 4.1.1 over the air with the menu. Often I got a network error, but then the Update from Stock 4.0 to 4.1 worked. (still no usb-debugging)
    After a factory reset in the options menu of JB (now) I can activate USB debugging again, but it is unrooted now.
    My tablet behaves very weird. Maybe the internal flash is broken. Somtimes writing of the flash memory doesn't end, eg after a download from the playstore. It stays at 100% for minutes. After a reboot it works without problemls. Unfortunately similar things happen again and again.
    So at the end I landed at Jelly Bean again, but with an unrooted Stock ROM. Let's see how it goes on.
    Original posting:
    Finally I finished the downgrade to 4.0.4
    I followed:
    [​IMG] Originally Posted by Ravak [​IMG]
    Or:
    With my Linux box I did as _root_:
    So I started with cwm for 4.1.1
    I installed
    superuser-3.1.3-arm-signed_md5_b3c89f46f014c9df7d23b94d37386b8a.zip
    a2109a_mcl0103_md5_2735494332747a425e283ed17230bea0.zip
    a2109a_icsbootloader_md5_15b243e9e2bad8236bbaf06c05a17351.zip
    Then I rebooted. I heared the Nvidia-sound and saw these "animated circles" but it never ended.
    So I did again the 2 commands above with my linux box (never disconnected the USB-cable)
    And I installed a2109_cwmrecovery-6.0.1.9c_md5_2a36e65e8e5289c67f59d1570eb9e3e6.img and rebooted.
    The tablet still didn't go on further than "animated circles", same es before.
    Now I did on my linux box:
    So I used the cwm for 4.04 now and wiped all the cache I found and installed
    Now the tablet asked me like in a new setup. Maybe I had to wipe at the beginning and this was the reason why it didn't start to the end.
ban rom goc idea tap a2207a-h
coby 7042 bootlader fastboot wipep
custom rom for lenovo a2207 tablet
how to fix ota update error on lenovo a2207a-h
mcl a2109a rom
mcl tablet
my mcl android
my mcl roms
