Help, I think I bricked my tablet
frfr1311
After rooting the tablet, it powered up but froze on the huawei logo. I removed the battery and now it does no longer power up. I read all the relevant post on this forum and tried all key combinations (e.g. send + back + power, etc.) but the tablet still refuses to switch on. Is the situation unrecoverable?
Thanks for your help
pvella
392
38
does it power up at all? Sounds like a power problem. Do any lights come on at all?
Sent from my HTC Desire using Android Tablet Forum
lanka53
12
Haha I did the exact same thing as you. I managed to fix mine by doing this:
- remove the mini sd
- turn on
- put the mini sd back in after it has booted up.
If that doesn't work, try taking the sim out and turning on.
Good luck :)
