Help If Possible Thanks
Discussion in 'Android Tablet Q&A' started by MadCat, Feb 21, 2012.
  1. MadCat
    MadCat Member
    Feb 21, 2012
    i recently went to ebay and got 10" ANDROID 2.3 TABLET PC MID WiFi Red EPAD 4GB X210 1GHZ HDMI 1080P TouchScreen but like i now learning theres a big problem with using it in uk >< apps etc... heres there stats i v got about it so far and im a real noob at this its nice tab but i think it needs the firmware upgrading ?
    Model = T10
    Android version = 2.3.3
    Kernel =
    Build = GRI40
    other specs i found on it as follows
    Browser UserAgent : Mozilla/5.0 (Linux; U; Android 2.3.3; en-gb; T10 Build/GRI40) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1
    Android version : 2.3.3
    Release Codename : REL
    API LEVEL : 10
    CPU ABI : armeabi
    Manufacturer : Infotmic
    Bootloader : unknown
    CPU ABI2 : unknown
    Hardware : imapx200
    Radio : unknown
    Board : unknown
    Brand : Infotmic
    Device : T10
    Display : GRI40
    Fingerprint : Infotmic/T10/T10:2.3.3/GRI40/eng.shine.20111221.154051:user/test-keys
    Host : smart21
    Model : T10
    Product : T10
    Tags : test-keys
    Type : user
    User : shine
    Data Activity: DATA_ACTIVITY_NONE
    IMEI(or MEID): 356988917458753
    IMEI/SoftVer: null
    MSISDN: 15555218135
    Registered MCC: zh
    Registered MCC MNC: 46003
    Registered Operator Name: China Telecom
    Network Type: NETWORK_TYPE_GPRS
    Phone Type: PHONE_TYPE_GSM
    SIM Country Code: zh
    SIM MCC MNC: 46003
    SIM Operator Name: China Telecom
    SIM Serial Number: 8986185718485539252U
    Subscriber ID(IMSI): 460035253000482
    VoiceMail number: +15552175049
    Roaming: false
    No Cell detected
    Background Data Usage: true
    type mobile[GPRS]
    state UNKNOWN/IDLE
    reason (unspecified)
    extra (none)
    roaming false
    failover false
    isAvailable false
  2. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
    Hi, MadCat, I have a similar Infotmic Tab , it works OK in the UK but you can have problems downloading Apps
    Try this
    Copied from another thread (unfortunately I've forgotten which one so cannot acknowledge!)
    I had the same problem when I first got it but it had instructions on how to fix it and it worked this is what I did
    1.go to settings
    2.go to applications
    3.go to manage applications
    4.go to all tab
    5.go to "market" application
    6."clear cache" then "force stop" - DO NOT CLEAR DATA go to "google service framework" application
    8."clear data" then "force stop"
    9.reboot your machine
    this is what I did and it fixed the problem
  3. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
