HELP restoring Gtablet
Discussion in 'Viewsonic gTablet' started by Israelroman, Nov 2, 2013.
  1. Israelroman
    Israelroman Member
    San Diego, California
    Viewsonic G-Table
    I am a newbie on tablets but I have some background on android cellphones, anyway my used tablet got stuck on blank screen and I tried to restore it unfortunately I was able to a certain point, It works but can't connect to Google play also if i turn it off it won't turn it on the only way It's if I nvflash it back in order to make it work, I tried to install clockworkmod but either I'm not doing it right or it's not working I NEED HELP !!! please
  2. Spider
    Chicago, IL
    Hi Israelroman, congratulations on your Viewsonic G-Tablet and welcome to the forum. Nice to have you as a member of Android Tablets. I'm moving your thread to the Viewsonic gTablet forum for you, where more people are likely to join the discussion and try to help you. Good luck!
help for gtablet
