Hi, I've just bought a Busbi7. It's all very easy to use but I need to set up a wireless network with WPA-Personal with TKIP Encription. It seems to have only one security option which is WPA2 and this doesn't work. Any ideas on how to change this?
You need to go into your settings in your broadband modem and change the wireless encryption to match your tablet. You should consult your modem manual to do this, access is via a browser or the setup disk that came with the modem. Hope that helps! Seasons Greetings!
Hi Anib, congratulations on your new Busbi7 and welcome to the forum. I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you. Good luck!
