How to tell which firmware to use on M701 (translated)
Discussion in 'Telechips TCC8902 Development' started by xaueious, Mar 29, 2011.
  1. xaueious
    Canada
    From 99pad by albertdsh
    Download: bootinfo.exe
    Instructions:
    1) YOU MUST BE ROOTED. Dump your boot.img. adb shell, or use a terminal app
    Code:
    cat /dev/mtd/mtd0 > /sdcard/boot.img
    2) place boot.img in the same directory as bootinfo.exe
    If your page size displays:
    nand chunk size 4096 -> old M701
    nand chunk size 8192 -> new HY M701
    If you get 128, you didn't dump boot.img properly
    • Like Like x 4
  2. keijames
    keijames Member
    NULL
    Does this work for styleflying GPAD ?
  3. JiePieWie
    JiePieWie Member
    Hmm. Just did this firmware-check and this was the output:
    L:\>BootInfo.exe boot.img
    Kernel size = 5082432
    Ramdisk size = 804915
    Second size = 0
    Page size = 4096
    Nothing about 'nand chunk size' but the page-size is 4096. Does this mean i have an old version ?
  4. ropodope
    ropodope Member
    NULL
    Yes
    ropodope
    Sent from my Vaelpak 3.2 RC2 Evo 4g. Flash and ye shall receive.
