Need Advice
Discussion in 'Android Tablet Q&A' started by CarolinaClay, Mar 26, 2011.
  1. CarolinaClay
    CarolinaClay Member
    Union, SC 29379
    Ideos S7
    :confused: I am new to Android tablets , but have been using a Droid X smart phone for about 3 months. I purchased a Ideos S7 from Best Buy 2 Weeks ago and returned it yesterday. The battery life and touch screen sucked.
    I need some suggestions on a replacement. I have thought about an IPad2. Any sugestions????
    Just picked up a Motorola Xoom Wifi. Can't wait to put it through it's paces.:)
    • Like Like x 2
  2. rico2001
    rico2001 Senior Member
    Charlotte, NC
    NOOKcolor
    A Nook Color is a good tab in that price range. It only lack cam and Bluetooth (custom roms can enable Bluetooth function). If you have around $340-350, the Viewsonic G-tab would be my next pic. Check out both sections here and see if either would suite your needs.
    Nook
    Viewsonic Tablets
    Nook Color
    OS - Android 2.1 (2.2 will be avaiable in April 2011)
    Screen - 7" Multi-touch Capacitive TFT LCD with 1024 x 600 resolution (169 dpi), anti-glare, 178° viewing angle
    Processor - 800 mHz Cortex A8 processor
    Ram - 512 MB
    Internal storage - 8GB (1GB app space), microSD card slot supporting up to 32GB
    4010mAh battery, 8 hrs
    WiFi b/g/n
    Bluetooth (none at the moment, likely enabled with custom rom)
    3.5 mm stereo headphone jack
    1 mono speaker
    micro usb port
    Size - 205mm x 128mm x 12mm
    Weight - 447g
    $250
    Viewsonic g tab
    OS - Android 2.2
    Screen - 10.1" Multi-touch Capacitive TFT LCD with 1024 x 600 resolution (118 dpi), LED driver system
    Processor - 1GHz NVIDIA Tegra 2 Dual-core ARM Cortex-A9 CPU
    Ram - 512 MB
    Internal storage - 16GB (1.6GB app space), microSD card slot supporting up to 32GB
    Front-facing 1.3 megapixel camera
    3,650mAh battery, 8 hrs
    WiFi b/g/n
    Bluetooth
    micro usb port
    usb port
    Dock for HDMI/Headphone/USB (optional)
    Size - 267mm x 173mm x 14mm
    Weight - 703g
    $340-350
    • Like Like x 2
  3. legs74
    legs74 Member
    CT
    8" MID Android 2.2, Droid X
    Motorola Xoom. I just took a look at it. Great touch screen. If you have nails, you are still going to have to use the pad of your finger, but it has great sweeping motion. It has a lot of features including the Ntegra dual core chip, cameras, etc. Verizon is selling it now, however I just got an email from Costco that they are accepting pre-orders at $589.00 with no contract to a carrier. Just a suggestion as an alternative. It has the Market installed so no rooting necessary. Nook is a fine device but needs to be rooted I believe?
    • Like Like x 2
  4. mirkosvw
    mirkosvw Member
    I prefer Samsung Galaxy P1000 Tab, there is istinata.Toy is old already needs a new one.
