Timeline
27
mee too , I meet the same problem
for pa_s7-2.99-20NOV2012-022923.zip, yesterday I used the gapps Konsta kang.zip, after install gapps jb last version "http://goo.im/gapps/gapps-jb-20121011-signed.zip" is suitable for android 4.1.2, previous problems are rare, but sometimes the clock would not update in the notification. now I never install gapps Konsta kang again, because if we update google search from android market, then the application voice search will be doubles. Now I am confused how to make several applications such as Boat Browser and Twitter to be compatible in a play store? I've tried in cm10 tablet ui 120 dpi and paranoid, I also edit and modify build.prop from multiple applications like lcd density pro version, but it still does not work.
Timeline
27
could someone try on a linaro build with adding this to build.prop?
Code:
net.dns1=8.8.8.8
net.dns2=8.8.4.4
net.ppp0.dns1=8.8.8.8
net.ppp0.dns2=8.8.4.4
net.rmnet0.dns1=8.8.8.8
net.rmnet0.dns2=8.8.4.4
mobiledata.interfaces=ppp0,gannet0,rmnet0,rmnet1,rmnet2
what effect? is only valid for Linaro rom? what if I edit on the other cm10 and latest paranoid? whether it can directly "copy-paste" in build.prop? Thanks for your hard work.
asturel
143
97
it didnt fixed the issue what i wanted to fix.. it overrides the dns servers ;> works on all rom
cnanyi
21
Now , I use the old version cm-10-20121119-EXPERIMENTAL-s7-linaro-asturel.zip without gapps (I'm in china the google service is broken, so It's not necessary to install it), the notification is working ,but there's no Tablet ui :(
dzonikg
193
20
cyanogen mode does not have tablet ui..if you want tablet ui use paranoid
cnanyi
21
Sorry for my poor english , I means the paranoid version has some problem for me (the notification always frozen)
so I choose the CM version :)
MyWorld
15
Man I'm impressed with the paranoid ROM!
It has been on standby for a week now without needing a recharge. I was busy fiddling with my S2 and neglected the S7 Slim a bit, got it out today cause it will need a recharge after a week of no usage.
Nope, still has some power left! WOW, did not expect that!
Thank you so much for breathing new life into our tablets, I love these ROMS, keep up the fine work you are doing!
tjbridge
12
is there any step by step guide on how to install recovery and flash it? I have just successfully rooted my phone. Don't know what to do after...
Unikum
8
anyone can test Goo.im Downloads - Downloading cm-10-20121127-EXPERIMENTAL-s7-asturel.zip ? i got access to goo.im buildbox (so i dont need my pc anymore), and i need someone who can confirm everything is ok (nothing new), if someone can feedback that mobile data works it would be great ;> thanks
It works for me just fine, I tested hw accelarated video (in MX player), wifi works well, Youtube works fine too, browsing is okay too. I couldn't test mobile data though.
On side note: does anyone know how to force youtube to play in HD? It works in Paranoid Rom with tablet layout Youtube app, but I would like to use it on the plain CM10 version too.
Nvm, I found a solution for it: http://forum.xda-developers.com/showthread.php?t=1529715
tjbridge
12
I installed cm-10-20121108-EXPERIMENTAL-s7-asturel. Works awesome but I noticed one problem, I hear a popping noise on my left speaker from time to time...
I formated everything in internal sd, sdcard, external sd and then updated to cm-10-20121122-EXPERIMENTAL-s7-linaro-asturel but still the problem is there.
EDITED:
What are the major differences of CM10 and paranoid ROMs? Thanks for giving some info on these..
Unikum
8
EDITED:
Paranoid ROM has the options to change the layout of your apps individually, the dpi, and can switch between tablet ui, phone (stock) ui, and phablet ui. I tried it for a week with tablet ui, the latest 2.99 one, it looks nice, but it had more hickups than the plain CM 10 ROM (I think this might be because it is a test ROM, according to paranoid), and the navigation bar is buggy in tablet ui (but I think it will be fixed soon). Take a look at this post, it explains well imo how this ROM works.
asturel
143
97
I hear a popping noise on my left speaker from time to time. Anyway I could fix this?
no, huawei didnt released the new kernel source where its fixed. you can ask for it from them. i have tried once and got an human droid auto WTF reply, so i gave up. i also tried few things (delay between powering on the dsp and adjust the volume but no luck) but im out of ideas.
